Speedometer, Power steering, A/C don't work after doing clutch.
Old 09-17-2024, 11:09 AM
Kyzer Hartley's Avatar
Hey yall, I did the clutch on my 2006 Cobalt SS 2.4L, and after I got everything buttoned up the power steering message came on the instrument cluster, as well as the speedometer and A/C stopped working as well as all the other things you can see in the message part on the instrument cluster. (Mpg, Coolant temp, trip A & B, and Miles left on tank.) It just shows dashes for all of those. Looking it up all I can find is TCM going out but seeing as my cars a manual it doesn't have a TCM. I did unplug the battery for about 10 minutes and the power steering worked for abut 5 minutes and then stopped again. I checked all the fuses and they were good, i'm not entirely sure what to check next so really any insite here would be helpful.
Old 09-17-2024, 11:17 AM
ProfDNS's Avatar
Check your grounds, you would've had to unbolt the one on the side of the transmission to get it out.
Old 09-17-2024, 11:26 AM
I did unbolt 2 grounds that were connected on the same spot on the bellhousing, which those 2 are connected I had to go back through and reconnect them. Is there another one twords the back of the engine on the transmission your talking about?
Old 09-17-2024, 03:12 PM
ProfDNS's Avatar
There are a total of 5: 2 on the engine, 2 on the transmission, and 1 on the body. The major factor is that these tend to corrode easily (I've had to deal with this recently), so make sure the eye connector itself is clean, and where it's bolted to is clean.
EmperorJJ1 (09-18-2024)
05misfire
01-09-2020 11:28 PM
bradchandler
04-02-2010 12:27 PM
VictoryRedLT
07-23-2009 05:55 PM
knighthawk
11-22-2008 11:17 PM
Jasper33
05-21-2007 03:15 AM
Quick Reply: Speedometer, Power steering, A/C don't work after doing clutch.
