07 Cobalt SS brake/ clutch won't hold pressure
All,
I was driving around the other day and lost brake and clutch pressure. I can momentarily get the pressure back up in both pedals by pumping the clutch or brake. However, the pressure is lost quickly.
There are no signs of any brake fluid leaking under the car. I am currently am in the process of bleeding the clutch lines and brake lines. I have the fuse box out, and the wheels off. Before I put anything back together, I wanted to ask the group if anyone has any other trouble shooting i can do, or parts to check.
The only thing i have done to the car this past month was change the brake bads. I did use a brake pad tool to spread open the new pads in the caliper. Perhaps i damaged the calipers while doing so.
Any help would be appreciated.
kzak104
04-13-2012 08:32 PM
