el paso thread
#1628
Thats not completely accurate. From 1997-2000 acura made the D16Y8. However, it was in canada only but a lot of them found their way to the U.S eventually,
* Displacement : 1,590 cc (97 cu in)
* Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
* Rod Length : 137 mm
* Compression : 9.6:1
* Valvetrain: SOHC VTEC
* 127 hp@6600 rpm
* 102ftˇlbf (144 Nm)@5500 rpm
* Head Code : P2J
* Piston Code : P2P
* Redline 6900 rpm
* ECU Code : P2P
* 127 hp@6600 rpm
* Head Code : P2J
* Piston Code : P2P
* Redline 6900 rpm
* ECU Code : P2P
#1643
what counter are you going off of? maybe mine just isnt adjusted for february being short...
thanks! and a meet sounds great
oh HELL yeah.. you know it. ima get hammered!!
![lol](https://www.cobaltss.net/forums/images/smilies/icon_lol.gif)
Last edited by CobaltArmyDude; 02-12-2009 at 01:11 PM. Reason: Automerged Doublepost
#1646
u better david at 8 am i will be there cuz i work at 9 so ill let u drive my car to my work lol so u can drop it off and angel will drive u back to the shop ok sound good?
