Alabama
#6077
![](https://dl.dropboxusercontent.com/u/40719330/ambassador.png)
YOU MAY BE A TRUE ALABAMAIAN IF....
1. You can properly pronounce Andalusia, Boaz,
Centreville, Eufaula, Fyffe, Montevallo, Opelika,
Sardis, Sylacauga, Talladega, Tallassee,
Tuscaloosa, Tuscumbia, Wedowee, or Wetumpka
2. You think people who complain about the heat in
their states are sissies.
3. A tornado warning siren is your signal to go out
in the yard and look for a funnel cloud.
4. You know that the true value of a parking space
is not
determined by the distance to the door, but by the
availability of shade.
5. Stores don't have bags or shopping carts, they
have sacks and buggys.
6. You've seen people wear bib overalls at funerals.
7. You think everyone from a bigger city has an
accent.
8. You measure distance in minutes.
9. You go to the lake because you think it is like
going to the ocean.
10. You listen to the weather forecast before
picking out an outfit.
11. You know cowpies are not made of beef.
12. Someone you know has used a football schedule
to plan their wedding date.
13. You have known someone who has a belt buckle
bigger than your fist.
14. You aren't surprised to find movie rental,
ammunition, and bait all in the same store.
15. A Mercedes Benz isn't a status symbol. A Chevy
Silverado Extended Bed Crew Cab is.
16. You know everything goes better with Ranch
Dressing.
17. You learned how to shoot a gun before you
learned how to multiply.
18. You actually get these jokes and are "fixin' " to
send them to your friends.
19. You have used your heater and air-conditioner
on the same day.
Finally:
You are 100% Alabamaian if you have ever had this
conversation:
20. "Wanna coke?" "Yeah." "What kind?" "RC"
is not
accent.
going to the ocean.
Dressing.
on the same day.
Finally:
conversation:
#6084
Sweet man yeah I never knew about a fb page. Im just looking for people to hang out/work on cars that know more about the lsj than I do. yall do any car meets? We have one every Saturday called cars and coffee. We also have asphalt hero meets in which we drag/have shows or cruises. ever heard of them?
#6085
When I first got my cobalt back in 08, I would go to a meet out in Pensacola at the bay front. If your interested in that, I can give the actual address where they meet up on saturdays at 9 or so.
#6086
No I haven't. And to be honest, I may go to about a meet every 2 years or so. I usually have too much going on. But I know of a meet in mobile that they do on Fridays and Saturdays. It's in the academy parking lot off of airport blvd. it's usually late though, like 10-1030. I'm typically in bed by then.
#6087
i hear ya man. pensacola is really only an hour from mobile, but i wouldnt make the drive to make it to either for a meet from bham. theyre usually pretty dull and cobalts get little respect down here even still.
there isnt much that goes on in mobile unfortunately. i dont know any cobalt ss owners that are really into their cars down here. i guess im a bit of a rairity for actually liking my car enough to want to keep it for 8+ years.
but yeah, if you ever need any help with your lsj, give me a shout. ive done all the work for my car in the last few years from stage kits to replacing clutches. i tune mine with hpt too, but dont have any experience with anything other than stage kits at this point. pretty soon ill be installing a ported head which im hoping will really be a nice power increase
#6088
![Twothumbsup](https://www.cobaltss.net/forums/images/smilies/twothumbsup.gif)
#6089
i hear that man. i havent done cooling mods on my car only because i could not justify the cost. been on a 2.8" pulley and stock cooling for 3 years now or so. the way i saw it was that i could easily spend 500 bucks on all of the cooling mods and sustain a bit of power in the summer, or i could spend a bit more and get a bit of cooling and more power out of a ported head all the time.
not trying to talk you out of cooling mods. they have their place, i just wanted the cheapest power i could make. the low end torque of a smaller pulley is worth it to me. that 3k rpm to 6k is usually where i run my car hard anyways
#6090
Yeah idk man I run my car decently hard every day. And reliably for three years? that's insane!
#6091
the cooling mods arent really a safety measure to me. before the cobalt came out, guys were running the same supercharger kit on the 2.2 and 2.4 cavalier with absolutely no cooling at all. not even the water to air that we come stock with. intake temps of over 200 degrees with no adverse affects other than a big drop in power. as long as you dont see any knock and air to fuel ratio is in check, its good to go. the cooling is really just to help keep the incoming air density high to maintain peak power.
the highest ive seen my iats is 165 degrees in the summer on pulls to 120 mph. at the end of the day, its all about what you want. i feel comfortable running my setup, because i did the tuning. id probably want to be as safe as possible if i let someone else tune it
#6092
How much would you charge for some diag? my coolent temp gets up to like maybe 220 on a really hot day and I know my a/f ratio is off but cant figure it out! its making me mad! I had to holes in my fuel lines and got those replaced.. so the big problem is out but the CEL keeps coming back after a trip or two if I clear codes. they are MAF codes but its a brand new MAF maybe a week or two old.. any suggestions??
#6093
#6095
who put the maf in? is there a possibility that it was put in upside down? the opening in the maf should face the ground. just a quick observation. i would definitely check the wiring and make sure it didnt get pinched somewhere. also make sure that your filter is correctly seated, and the intake is hooked up all the way around.
and the coolant temps are a bit high, but normal. keep in mind that the intake air temps and coolant temps are 2 totally different things. normal engine coolant temps are 170 - 190 degrees. hot days while idling may see 220. turn your ac on full blast and the fans will kick in and keep cool the engine coolant temps a bit. but 220 isnt a bid deal by any means
and i dont charge anything. just try to help out where i can
#6097
