Orlando, FL peeps check in!
#3582
#3583
thank you sir! .........and jeremy but since he left the lug nuts in his truck i had to buy some but there on and thats all that matters. now for turbo. ALSO JOSH! you never answered my question about the date to come up. there maybe a slight change because my cousin is coming from washington and its her birthday so i cant miss it. let me kno when your available so i can plan this out.
#3585
with my cousin coming down the is ******* everything up
#3586
but what are you gonna flash in the base tune with? jeremy's hpt? cause you will need a $100 credit from him. and then i would have to unlock your car on my hpt as well
#3590
#3591
I didn't use primer when I painted the trim. I washed it, sanded it down a little, wiped with isp alochol and painted using Kyrlon Fusion. 3-4 coats. I haven't had any problem with flaking or anything.
#3592
u use fine or rough sand paper. n do i need a spray paint for plastic or ne kind will work
#3593
I used 1500 grit paper. I would use paint made for plastic. Its made for plastic for a reason...
https://www.cobaltss.net/forums/show...ighlight=paint
just a vague guide to doing this.
#3594
#3595
Ah snap road trip party at josh's house.
Mike the rims gave your car a whole new look, need to get those calipers painted.
#3598
Where did you get the lugs from?
I was out all day yesterday when you called without a car so I had no way to bring them to you. Plus I could hardly hear you on the phone. Yours or mine was cutting out. iunno.
