South East MS, AL, TN, GA, SC, NC, and FL
Orlando, FL peeps check in!
Old 04-24-2010 | 08:35 AM
  #4726
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by cobaltdreams
the hahn racecraft pipes should be perfect since its the hahn BOV right im new to this car so im learning thanks for not being D bags about my lack of knowledge.
nope. before you order any pipes, give the manufacturer a call and tell them what BOV you plan on running so you can get the proper flange
Old 04-24-2010 | 10:40 AM
  #4727
Darkmanx's Avatar
No one wants to buy some 80lb either? wtf
hey josh u got 42lb and a harness or just the harness?
Old 04-24-2010 | 12:41 PM
  #4728
jonnymerk's Avatar
I wouldn't mine having 80's I just don't have injectors that you would use if you're goin back stock let alone stage 2. I have something like 72's with a controller....that's why I want the 80's just to be rid of that set up.
Old 04-24-2010 | 01:07 PM
  #4729
BLAZIN07SS's Avatar
I'm too JDM for you
i sold my 42's. i only have whats on my car pretty much
Old 04-24-2010 | 01:11 PM
  #4730
Darkmanx's Avatar
Ooh well . Guess there going too
Old 04-24-2010 | 02:03 PM
  #4731
USMCFieldMP's Avatar
Rattlesnake Race Shop
Hey, just a suggestion, but have another Exhaust hanger put on to that Side-Exit, near the tip. One isn't enough. That's why I had so many problems with Turbo Bolts loosening... because the exhaust was bouncing around, shaking the turbo bolts loose.
Old 04-24-2010 | 02:05 PM
  #4732
BLAZIN07SS's Avatar
I'm too JDM for you
really? from the mani-to-turbo or the turbo-to-downpipe? cause i am running studs on the turbo mani. either way its no big deal to add a hanger
Old 04-24-2010 | 02:08 PM
  #4733
The mani-to-turbo bolts. I swapped the bolts out for studs a month and a half ago... and it got much better, but it'll still loosen them up every now and again. I had a sneaking suspicion that the one hanger was the root of my problem and rigged up something to hold the tip steady... haven't had any problems since then.
Old 04-24-2010 | 04:57 PM
  #4734
Dr.Balt407's Avatar
i have stock injectors with harness
Old 04-24-2010 | 11:30 PM
  #4735
Neyo's Avatar
braulio any idea on the size of the plug for the H/E? this is definately a must fix, for me dam valve sits too low thing opened up on me twice
Old 04-25-2010 | 07:09 PM
  #4736
cobaltdreams's Avatar
hey Dr balt can u send me a link or some thing on the exact name or specs on the BOV so i can make sure i get the right flange for it form HRC. thanks
Old 04-25-2010 | 08:22 PM
  #4737
Dr.Balt407's Avatar
its the one for $229.00 http://www.turbosystem.com/engine/Tu...martHRCBOV.htm
Old 04-25-2010 | 08:35 PM
  #4738
Darkmanx's Avatar
Anyone got a stock exhaust for me.?
Old 04-25-2010 | 08:42 PM
  #4739
Dr.Balt407's Avatar
josh, he's doing his swap soon so check with him.
Old 04-25-2010 | 08:44 PM
  #4740
BLAZIN07SS's Avatar
I'm too JDM for you
i dont think thats soon enough for him
Old 04-25-2010 | 08:59 PM
  #4741
Dr.Balt407's Avatar
i see.........
Old 04-25-2010 | 09:11 PM
  #4742
Darkmanx's Avatar
ya hes too ******* slow on turboing his car.
Old 04-25-2010 | 09:12 PM
  #4743
BLAZIN07SS's Avatar
I'm too JDM for you
waiting on parts fgt
Old 04-25-2010 | 10:18 PM
  #4744
silvercobalt07's Avatar
if u pay for mine to b takin off u can have it ill go wit a muffler delete
Old 04-26-2010 | 05:38 PM
  #4745
Rydis's Avatar
so changed the plugs...still getting knock :/. Old plugs still looked pretty damn clean too. WOT in 2nd I didn't see any, WOT in 3rd, knock starts around 4-4500 rpms. Hits about 1*..then next second as high as 5*, then drops back down again real quick, and will spike as you continue WOT :/.
Haven't been past 3rd WOT to test too much as I figured 3rd WOT knock was bad enough ..
Seeing some random knock just cruising too (not between shifts)..any other ideas?
Plugged at .35 also.
Old 04-26-2010 | 05:45 PM
  #4746
Dr.Balt407's Avatar
He needs the whole catback not just the muffler, anddont even try amuffler delete on a sc lol it only sounds good with turbo cars.
Old 04-26-2010 | 05:50 PM
  #4747
Marca34's Avatar
try gapping .32 thats what ottp recommends. Plus how much timing are you running?
Old 04-26-2010 | 07:12 PM
  #4748
he can take everythin ill b like my brothers camaro u heard that thing mike loud as ****
Old 04-26-2010 | 07:52 PM
  #4749
Hey all i have a meet going on tonight drbalt will be there and some other eco fans wanted to extend the invite to u all.
its located at 2721 forsythe rd u can miss it really easy so look hard its in a warehouse district so we dont get cops called and i also own one of the bays so they cant kick us out. if u want more info PM me.
Old 04-26-2010 | 09:38 PM
  #4750
Rydis's Avatar
Its the OTTP tune, so whatever they set it as for a similar setup on Brandon and Terry's old car. Ill try backing the gap up to .32 see if I see a difference.
Just weird that it started out of nowhere to me.
Quick Reply: Orlando, FL peeps check in!
