Arizona BS Thread
#4626
im going to need a couple days. i have to build the motor, intall the new clutch and flywheel and then install the turbo kit. i will need to modify my current cp so i can mount the bov and recirculate it
#4628
If I'm out of the hospital and doing well I'll help out or just keep you company.either or I don't have many friends so anything that gets me out of the house is good
#4633
The causes of a low MAP sensor signal circuit (P0107) could be any of the following:
Bad MAP sensor
Open or short in the signal circuit
Open or short in the 5 Volt reference circuit
Ground circuit open or shorted
Bad PCM
#4634
Really? i went to autozone and got the free scan and on the slip it says map or maf. The boost levels are the same so im guessing your right damn maybe i should try to warranty this one.
#4638
no there is no symptoms just a CEL the car runs fine
#4649
