Arizona BS Thread
#4776
Ok.
Just to let you know 80's are cheap now
https://www.cobaltss.net/forums/part...ys-pcm-233733/
New they are about 200...
That is all you need to have E85... Well and a tune from me.
#4777
Ok.
#4780
I cant remember the site that has all the places in az with E85...
Until they are every couple miles I suggest a 5 gallon race tank for the trunk. Some of us do it, helps out a lot.
Edit: I think there is one at 9080 W. olive too, just off the 101. Have not been there though.
A couple in Scottsdale, couple near down town phx, couple in tempe, couple in Mesa...
#4781
59th and Olive is kinda close to you since you live by arrowhead. They are all over and I am seeing more pop up.
#4787
That hybrid will likely be 5-10% less efficient (max whp on a regular GT2871 is approx 455-460 whp this turbo will be 5-10% less more than liekly) than a regular GT2871 due to cramming a huge compressor wheel into a smaller K-04 housing that has been machined to make it a larger. It should spool up very quickly but I am still a little worried about surge issues with that wheel in the K-04s housing.
#4788
I get a little over 250 miles on a tank now (freeway). It doesn't bother me. Sticking with meth and blowing my engine, due to tip in knock or pump failure, would be worse than the fuel economy.
#4793
just took my test ahhhhhh im a lil nervous there was some stupid questions but it shut me down at 80 questions and everyone told me i should be fine. i find out later today or tomorrow my results i need a drink now
#4799
Not sure on the adjustment it was a PITA to install apparently as well. He did the mod to help with shifting issues but it turned out that the clutch needed more bleeding and a different type of fluid added to it.
