South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 05-16-2011, 03:11 AM
  #10976
1LowLS's Avatar
Originally Posted by 08ssedan
Lmfao. Whatever man.
well jesus fkn christ quit acting stupid.anyways im done good bye all
Old 05-16-2011, 03:25 AM
  #10977
Raiden8816's Avatar
Originally Posted by smthomas556
Are there any coupes on here that need a ZZP tipple gauge pod? I have one for sale.
how much? im curious
Old 05-16-2011, 03:36 AM
  #10978
Cobalt096's Avatar
Woot Woot ! New Heatexchanger is in !
Thx Chris for all the help, good lookin out man.
And FYI it still took another 2 necks full of water.
Old 05-16-2011, 04:07 AM
  #10979
IonNinja's Avatar
https://www.cobaltss.net/forums/pict...t-pics-250926/
Old 05-16-2011, 04:12 AM
  #10980
Cobalt096's Avatar
Originally Posted by Raiden8816
x2 nothing to prove at the track til the sc is on and fully tuned (stock pulley + corn)
Almost time......
Question ? what is your goal for the 1/4 mile ?
Old 05-16-2011, 07:14 AM
  #10981
tglems's Avatar
Just sent my advisor my first draft of my thesis. It is only 140 pages right now, and I'm sure there will be plenty of edits coming my way in the next couple weeks, but on the plus side it seems that working 40+ straight days of 14hrs/day is paying off
Old 05-16-2011, 11:26 AM
  #10982
08ssedan's Avatar
When will it be finished?
Old 05-16-2011, 12:00 PM
  #10983
SCcobaltSS's Avatar
I figured it was going to need more. Check it over the next few days to be sure its all the way full. It sometimes takes a long time to get all the bubbles out.
Old 05-16-2011, 12:08 PM
  #10984
sundevil07's Avatar
Right on Tyler get after it!
Old 05-16-2011, 12:20 PM
  #10985
smthomas556's Avatar
Post 10966... No one caught it
Old 05-16-2011, 01:11 PM
  #10986
FF_ace's Avatar
what a pita my car is being. right now it idles kindve funny until it warms up then everything runs fine and for some reason it dosnt want to boost more than 16psi. term has it commanding a lot more. and the last log it showed it was only flowing 23 ve lbs/min term and i thought it would be flowing more
Old 05-16-2011, 01:25 PM
  #10987
SCcobaltSS's Avatar
When someone else switched turbos didnt they have an issue with it not boosting over a certain amount? It was an LNF guy...
Does he know why the VE and MAF airflow was so drastically different? I thought MAF was the closest to correct and the VE is more calculated..
Old 05-16-2011, 01:46 PM
  #10988
Terminator2's Avatar
VE and MAF are both calculated values but his car is flowing about the same as the stock turbo at 15 psi right now. Not sure why yet. If the compression and leakdown test comes back good then we have to see if the wg is being a bastard because I am commanding 28 psi and 100% wg dc and it is seeing 100% wg dc and desired boost is pegged but the boost will not go above 16 psi.
Old 05-16-2011, 01:50 PM
  #10989
Originally Posted by Tundraboarder666
yOU'RE GONNA BE PAYING THE TUNER NOT JUST THE ABILITY TO HAVE IT UNLOCKED. GOTTA TAKE INTO ACCOUNT THE TIME THAT THEY PUT INTO IT AND THE TIME IT TAKES THEM TO DATALOG AND TUNE YOUR ASS.... HOLY CAPS LOCK... I'M NOT RETYPING IT ALL LOL
Just ask Nick how much time I have spent on his ever changing setup.
Old 05-16-2011, 02:07 PM
  #10990
FF_ace's Avatar
I think it might be the wastegate might need a stronger spring or maybe ditching the boost solenoid and going with a mbc we will see after the compression test
Old 05-16-2011, 02:09 PM
  #10991
FF_ace's Avatar
Ya numerous hours and hundreds of logs and we are still tuning it
Old 05-16-2011, 02:17 PM
  #10992
sundevil07's Avatar
Mbc time nick! Your compression test will be good! :positive thoughts: lol
Old 05-16-2011, 02:25 PM
  #10993
Might be a weak wg spring. Do you have a heavier spring just in case assuming the compression test comes back good?
Old 05-16-2011, 02:28 PM
  #10994
SCcobaltSS's Avatar
He was like 155psi across the cylinders last we checked. I think its the stock controller. MBC for sure...
Old 05-16-2011, 02:49 PM
  #10995
Tundraboarder666's Avatar
Yeah that was Tyler He had that same exact problem.
Old 05-16-2011, 02:59 PM
  #10996
Somehow it drank a quart of oil since his last oil change.
Old 05-16-2011, 03:16 PM
  #10997
1LowLS's Avatar
im posting just for you Nick.You didnt plug the 3rd port on your factory boost controller did you?If so that needs to vent to atmosphere.Tglems capped his and his was doing the same.It boosted normal a bunch of times then all a sudden it wouldnt go over 15-16 pounds.
Old 05-16-2011, 03:24 PM
  #10998
Yup yup I was there to see this.
Old 05-16-2011, 03:25 PM
  #10999
SCcobaltSS's Avatar
I am guessing that is partly from the PCV leaking. Also his car shot smoke out in shift, I am guessing from not enough crank case venting.
I think it is to atmosphere actually.
Old 05-16-2011, 03:29 PM
  #11000
tglems's Avatar
I was there to see it. In the end it worked out because I found two leaks that I plugged while trying to figure out what went wrong before figuring it out and everyone telling me that Steve had told me that weeks ago. I'm a dumbshit :-)
Quick Reply: Arizona BS Thread
