South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 06-19-2011, 11:53 PM
  #13126
FF_ace's Avatar
Is that the 2nd one youve been through? Stronger spring
Old 06-19-2011, 11:58 PM
  #13127
drewbroo's Avatar
Originally Posted by Tundraboarder666
Anyone have any suggestions for my boost issues?
pm me the specifics of your setup, I might be able to help.
Old 06-19-2011, 11:59 PM
  #13128
drewbroo's Avatar
Originally Posted by Josuizzle16
Hey Cobalt dudes that I saw at QT on 48th St & Baseline.. Guess what happened... I raced my car and when I was putting that bastard into 3rd the power stopped pulling it was like if I put it into 5th gear and the check engine light would blink on and off.. Anyways I was running 14.6's .. My dipstick popped out and it got all over my engine .. I went home put the thing to check the engine light on and it said I had a misfire.. I checked my spark plugs and the part where it was suppose to have a gap was gone on 2 of my plugs and the rest were black as ****.!! So I'm gonna buy some new cold ones and go back to the track this Friday if you guys are down to go..
was there some oil on your plugs by any chance? Usually when your pistons slap the **** out of your spark plugs like that its time for a new motor.
Old 06-20-2011, 12:06 AM
  #13129
smthomas556's Avatar
Blowby = Bye Bye.
Old 06-20-2011, 12:12 AM
  #13130
Tundraboarder666's Avatar
it's a gt2860RS turbo my number is 480 390 5664... It's still the stock internal wastegate... not sure what else to try at this point..
Old 06-20-2011, 12:16 AM
  #13131
06blackbalt's Avatar
Check all your couplers Tyler
Old 06-20-2011, 12:19 AM
  #13132
SSfamilywagon's Avatar
My s/c used to blow the dipstick tube alot and get alot of oil all over the motor too. What year is your car. You may need the upgraded intake manifold gasket. But before doing anything, do a compression test just like everyone is saying here to make sure the motor isn't hurt or blown
Originally Posted by smthomas556
Blowby = Bye Bye.
Not all the time, but usually
Last edited by SSfamilywagon; 06-20-2011 at 12:19 AM. Reason: Automerged Doublepost
Old 06-20-2011, 12:20 AM
  #13133
Yeah I know everything's good on it because I took the old MBC off and I was hitting 10 to 11 psi and now with the new one i'm only hitting 6 to 7 psi... I don't think it can bleed off enough pressure honestly.
Old 06-20-2011, 12:22 AM
  #13134
I see can you adjust the wastegate
Old 06-20-2011, 12:41 AM
  #13135
feliciano's Avatar
Originally Posted by SlowCobaltLT
Has anyone ever went to the speedworld wednesday night beat the heat thing
no i wanna go though almost went last wednesday but i watched tv instead its the first and third wednesday of the month
Old 06-20-2011, 12:48 AM
  #13136
Josuizzle16's Avatar
You blew your dipstick... lol
But I would compression check that bitch, sure you didn't hit 1st and not 3rd?
Yeah I'm gonna check that.. But do you know what part number the spark plugs are for NGK 2 Step Colder Copper Plugs ?? Anyone??
Old 06-20-2011, 12:56 AM
  #13137
Moobaby's Avatar
Heyyy what'd I miss?
Old 06-20-2011, 12:57 AM
  #13138
sundevil07's Avatar
hey i did that one time!
all you need is ngk 4644 i believe is the part number
Old 06-20-2011, 01:00 AM
  #13139
Was it just the plugs that was the problem for that happening .??
Old 06-20-2011, 01:03 AM
  #13140
SlowCobaltSS's Avatar
Damn I thought it was every Wednesday night not only the first and third Wednesday
Old 06-20-2011, 01:04 AM
  #13141
sundevil07's Avatar
nope, lost compression in number 4. what all did you have done to your car?
  #13142
08ssedan's Avatar
Errthang
Old 06-20-2011, 01:09 AM
  #13143
sundevil07's Avatar
brandon whats up with your sig?
  #13144
2.8 pulley, 3 inch catless exhaust, CAI, header, 80lb injectors.. I think thats it..!
Anyways my check engine light went on again it says misfire on cylinder 4.. Its more specific now lol
Old 06-20-2011, 01:16 AM
  #13145
sundevil07's Avatar
you know who tuned you or did you get the car used?
Old 06-20-2011, 01:21 AM
  #13146
No I know who tuned it I just put that stuff on this week and tuned it this week but it was doing good until the misfiring.. But how did you fix the problem .. ?
  #13147
08ssedan's Avatar
He was tuned by stageup haha
Old 06-20-2011, 01:25 AM
  #13148
sundevil07's Avatar
i bought a new cobalt
Old 06-20-2011, 01:30 AM
  #13149
lol nice..
Old 06-20-2011, 01:41 AM
  #13150
I know there's that little rod that moves from the wastegate to the turbo not sure if that actually adjusts it or not though. Drew called and talk to me about it. When I get home from work tomorrow I'm gonna look into it and see if I can see anything that could be setup wrong. But it's been setup this way since the turbo has been on so I'm not sure what it would be just yet.
Quick Reply: Arizona BS Thread
