South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 06-21-2011, 02:43 AM
  #13201
06blackbalt's Avatar
Yea his is oil an water cooled
Old 06-21-2011, 02:46 AM
  #13202
Tundraboarder666's Avatar
Yes it is water and oil cooled
Old 06-21-2011, 02:51 AM
  #13203
I'm starting to think you're right drew... It looked like it was coming from the coolant AN fitting on the turbo.
Old 06-21-2011, 03:04 AM
  #13204
1LowLS's Avatar
Posting just for ty.
I wouldnt think it would be yellowish green seeing your still running dexcool.wouldnt it be orangish redish or even more brown if it was coolant with oil,and it usually turns milky when mixed together.
Old 06-21-2011, 03:07 AM
  #13205
Well the **** that we put in before was the lime green stuff... the 'mixes with all' coolant. So orange plus lime green could make kind of a gold... maybe.
Old 06-21-2011, 03:10 AM
  #13206
1LowLS's Avatar
Ahhh very true.I forgot about that.Good point!its very possible its mixing somewhere.Check your dipstick to make sure its not mixing in the crankcase
Old 06-21-2011, 03:16 AM
  #13207
I checked it. It looked super dark lol
no milkyness, coolant level seems pretty normal..
Old 06-21-2011, 03:18 AM
  #13208
drewbroo's Avatar
Superdark isn't a good sign..... When did you change you oil last? Your engine was just built a while back right?
Old 06-21-2011, 03:24 AM
  #13209
It's at 34% according to the thing on the dash. I think I'm gonna change it on Wednesday though. I run full synthetic too.
Old 06-21-2011, 03:25 AM
  #13210
1LowLS's Avatar
Ya I know you need to change the oil and filter.its been a bit.but regardless thats not the problem here.I wonder if you have the oil feed and coolant feed fitting leaking and mixing,or maybe it was leftover when Jason built it and its just been sitting there?
Old 06-21-2011, 03:37 AM
  #13211
drewbroo's Avatar
The way the oil feed and coolant feed are positioned on the 2860, it could leak and mix. Also the C shaped "gasket" on the fitting could be cracked. The turbo and exhaust manifold are the only things exposed that get hot enough to congeal coolant or an oil and coolant mixture.
Old 06-21-2011, 03:40 AM
  #13212
1LowLS's Avatar
I dunno about this turbo as its been replaced,but when I put the original 2860rs on they were full copper "crush" washers
Old 06-21-2011, 10:14 AM
  #13213
SCcobaltSS's Avatar
Its that same turbo just has a larger exhaust side.
Old 06-21-2011, 11:35 AM
  #13214
drewbroo's Avatar
The crush washers was what I was referring to. If you take them out they should have a top and bottom washer with a small strip connecting them.
Old 06-21-2011, 11:43 AM
  #13215
1LowLS's Avatar
This is correct.Steve would know better than me but the new turbo should have came with new washers>?
And ya I knew it was the same 2860rs with larger exhaust housing,just wasnt sure if it shared the same CHRA
Old 06-21-2011, 12:35 PM
  #13216
SCcobaltSS's Avatar
CHRA is the same.
Old 06-21-2011, 12:43 PM
  #13217
smthomas556's Avatar
Originally Posted by SCcobaltSS
CHRA is the same.
Such anger...
Old 06-21-2011, 12:55 PM
  #13218
drewbroo's Avatar
Originally Posted by smthomas556
Such anger...
what did you do to your car man?
Old 06-21-2011, 12:59 PM
  #13219
SCcobaltSS's Avatar
Such anger...
lol no anger...
Old 06-21-2011, 01:33 PM
  #13220
That tree has a nice lowering effect on that car
Old 06-21-2011, 01:38 PM
  #13221
08ssedan's Avatar
Damn looks like i need the tree mod
Old 06-21-2011, 01:46 PM
  #13222
Conspiracy2Riot's Avatar
Looks like that's a real nice aero package he got installed!
Old 06-21-2011, 01:48 PM
  #13223
drewbroo's Avatar
brings a new meaning to the phrase "slammed"
Old 06-21-2011, 01:50 PM
  #13224
sundevil07's Avatar
3 bad jokes in a row boooooo just playin haha
Old 06-21-2011, 01:54 PM
  #13225
^^^Just jealous cause you couldn't think of anything!
Quick Reply: Arizona BS Thread
