Arizona BS Thread
Vince sucking? Idk It doesn't do it anymore... But I can only stay on it for a few seconds until it leans out. So I guess i don't know if it's gone for sure or not yet.
After I'm on it for more than like 3 to 4 seconds... Like that first time we did that blip on the N28th street was just for like 2 seconds and it was 10.2 to 12. No worries man we didn't really get to tune that part... We will soon Did you decide on Tuesday or Wednesday? And I'll bring a good $20! lmao
So, I've been searching for intank fuel pumps that are compatible with e85. I came across a company called "Deatschwerks" they have a intank pump that is 300lph but its only for Evos, subies, genesis, and a couple other cars. Theres a universal kit tho, any chance we could get this to work on the ss/tc?
Oops i just re-read ur post. The issue im trying to figure out is the fact that the 100% e85 is killing the fuel pumps after a while. im trying to figure out a fix for that.
time for new wheels and need suggestions. only requirements are 4x100 and 17" (already have tires 225/45-17)and under $1000 for all 4
going on this
going on this
Well drew was saying the e85 kills the fuel pump after a while. There has to be a replacement that is compatible with e85.
my point exactly. you can save a lil by not need a aftermarket pump for e85. i think i was the first ss/tc here to make the switch to the 1:1 blend benn running it for awhile now with no issues. im going to stick with the 1:1 blend but with my bigger turbo i might have to get the zzp cams which have a different size lobe for the cam driven HPFP that make a flow a lil more
1 to 1 blend is great if you get the mixture right almost everytime. You have to run your tank near empty every time to get an slightly accurate mixture. Get the mixture off and your fuel trims will be off. 70% offers more top end power then the 50% blend. But with LNF's.... the HPFP is suffering with anything north of 50%.
<------ this guy was the first with the E85 blend in the 2 door Compliments of Term
With the 2871 on my 2 door I was running out of fuel on the 50/50. You will need the cams to run anything north of 430WHP on the 50/50. You have a better change of seeing what you can do on an E30 Blend. THats what I have to run in the 2 Door. I just switched over to 91, and its still making very good power. Just no timing.
Bleh all these fueling issues..
It shouldn't be that hard to get the blend right. If you know your tank and where the marker is at... I'm usually able to guess pretty close to what actually fills it up.
And Drew
damnyouautocorrect.com You will find some good ones there haha Not as bad as us anyways!
And Drew
[QUOTE=SCcobaltSS;5876937]AHHH the old idle misfire code.... haha.. Yes I can with the cat I probably just forgot to disable the cat test... easy fix!
can we get rid of my p0300 too
( Without getting an oil change ) <------ lol, its true.
If I sell both my cars, I will be selling my HPTuners kit also. Anyone who thinks they can handle their own tuning I have 08-09 LNF's unlocked. So factor that into the price. Make me an offer.
We share the same thoughts, the fuel isn't adding power itself were just taking advantage of its resistance to detonation. I'm only running 20* up top but I could have ran more even just on the 50/50, no reason to stress the fuel system anymore when theres no gain to be had
My BS of the day:
ZZP Boost Reference Kit on its way! I hope that will solve the fueling problem I will inccur once I go full boost. I would rather not go ID1000's for my injectors. If I drop the base fuel pressure to 48psi at 30 psi boost my 80's should be close to 120#ers..
ordered new cat-back exhaust gasket once i get it taking it to performance muffler and see where its leaking hopefully not the manifold really dont want to tear everything out to weld it again
