Arizona BS Thread
lol some how, my blown 'fire would still be the slowest car there i need my tune and pulley bad...hopefully i can regain possesion of a p&p's blower here soon with a 3 inch on it.
I will run you and nick but only from a 40 roll. I will get a decent jump and see how long it takes you guys to catch up.
I actually have a boost leak right now. I lean out after 4 psi and I can here the leak. I need to have russ weld me up some charge pipes, atleast the cold side since that is where the leak is at.
lol of course... i was lucky i survived... ended up just getting the title notarized and given to the tow truck driver.... had a 2.9 pulley, 42.5lb lucas injectors, custom tune, corsa touring exhaust, injen intake, aem dry flow filter... projector headlights, billet grills
its probably being striped now as i type this... had i believe 110k miles...just changed the oil too, and have a brand new cabin filter i can't install now
was thrown out of the vehicle... when i came too i was on my feet walking out of a wash in shock
had fractured my jaw in three places, and a cerebral hemotoma for a lil while
Alright, ever since I did the ZZP BRFS anytime my fuel is nearing 1/8 tank it would go super lean if I am over 2k and over like 20% throttle. (I probably bent the float or something) Anywho, I was doing some pulls and was leaning out after 4 psi, but I had near 1/4... Well I just filled up because I wanted to see if it fixed this and it did. I did a pull to 10 psi and damn it felt good! I mean it fell on its face after that due to a 7.4 AFR because I was adding fuel to try to counter the lean before. So I just pulled 30% fuel everywhere out of the maf and I am going to do some more runs.
PS. I love when I see 109 IAT1 and 121 IAT2 after a pull.... its sweet!
So I leaned the car out a bit (about 2 points up top) and went for a ride..... Holy ****! This thing pulls like a raped ape. It feels like it pulls harder than a bolted LNF..... and Im only on 10 psi and 9.4:1 AFR right now.... I cant wait to hit 30 psi and 11.6 AFR. Its going to be nuts...
so i dropped the car off at performance muffler and the gasket i had ended up being the wrong size so i found my stock dp gasket going to re use that one. i had jose or whatever his name was that works for russ there check it out and he told me there was no leaks but i swear i here a tiny leak on cold start ups and when i put load on the engine i will take it back when russ is there i like dealing with him better
