Arizona BS Thread
i might be selling my mpx catback. might just roll with side exhaust
i dont like how when my ac is on my car shakes like a bitch like i have no motor mounts... ***** so annoying
Just got done tuning Jay (The guy that has Steve's old SC) and it runs a lot better. Found out there was no Intercooler fluid in the res. because of a broken cap.
His car was smoking due to rich condition, was slow, and had trouble idling got all those bugs worked out.
Next up, Lightningbolts car today after 6... 2 day 3 cars tuning.. Bring on the rest!
My bs of the day. Was making a u turn let the clutch out and i herd a pop and now clutch wont grab who wants to guess whats wrong. No oders or oul leaking
bad slave cylinder...same **** happened to me when my went out....they leak but it stay internal. get it fixed NOW or u will need a new clutch.
I was gonna say,if its loss of fluid/pressure(i.e bad slave or master) then the clutch will stay engaged and you wouldnt be able to get it in gear unless you turn the car off,or push the cr fast enough to get it to slip in to 1st while rolling,then drive it like a semi with no clutch.Happened in my s-10 when the line popped
so apparently slave cylinder went out causing the clutch to slam and disintegrate, in turn demolishing the fly wheel. so need clutch,flywheel, throw out bearing . ya new parts and since i was gonna use that money for college and i cant afford a class now time for new wheels and tires! and maybe springs
should i go excedy or spec for clutch?
