South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 02-22-2012, 07:31 PM
  #20251
SCcobaltSS's Avatar
Originally Posted by Trav3480
Well went out to Cali for Pres. weekend. Driving up to San Fran and Piston 4 went... Now gotta figure out out to get the car back to AZ and repaired somehow. Dealer wont fix it under warranty of course.
Were you going WOT at the time? AFR? IATs?
Edit:
He just told me he was cruising with cruise control at 65 all of a sudden CEL flashed, pegged 10:1 (max for AEM) then smoke.... Doesnt add up to a blown motor.
Old 02-22-2012, 08:31 PM
  #20252
1LowLS's Avatar
That sux trav :/
On a side note,my cooling fan quit working.Pulled the harness up for it and it lost ground somehow.Traced the wires all the way to the ecu and they looked fine.Looked at all my other wiring and the only thing fishy was my bank 1 sensor 1 o2.I had to extend it a while ago and I guess I left it sitting on the Tstat housing and one of the signal wires was grounded out.Re wired it and loomed it up and ziptied it,and the fan works lol.Fkn computers are weird.
Old 02-22-2012, 08:55 PM
  #20253
evofire's Avatar
stuck open injector?
Old 02-22-2012, 09:01 PM
  #20254
SCcobaltSS's Avatar
What the 10:1? Lost compression, excess gas not burned or, hopefully, the spark plug is done for and allowed unburnt fuel to flow.
Old 02-22-2012, 10:24 PM
  #20255
sundevil07's Avatar
What was the code? Flashing CEL indicates catalyst damaging misfire, narrows it down to fuel and spark without knowing the code and going off the provided info it sounds like either the plug/coil pack/injector went full retard. Obvious diagnosis is obvious
Old 02-22-2012, 11:47 PM
  #20256
IonNinja's Avatar
Originally Posted by 40rty
This all came in today minus carillos
sweet
Old 02-23-2012, 10:15 AM
  #20257
Trav3480's Avatar
Thanks all for the help, The car is in Patterson Cali right now where it was towed and I had to get back to Phx.... so all I know is what the dealer service manager is telling me. He is stating piston 4 lost compression and needs to be replaced and cost is 5k... I myself believe that they have no clue about anything and just want to replace the motor.. hence the reason they are denying warranty service is cai ( I realize other mods void it anyway, but picking CAI just screams retard imo ) . I dont know what coded at this point until I can speak to service guy again. Just cel flashed , AEM pegged at around 10:1 or so, turned car off, restarted no Cel but sounded bad, would idle for bit then died, if gas pressed white smoke
Old 02-23-2012, 10:57 AM
  #20258
Tundraboarder666's Avatar
Yeah sounds a little fishy to lose compression on cyl 4 if you're just cruising... especially to blame it on your intake
When I lost compression on cyl 4 my car idled and drove fine until i got higher in the RPM's. I'd be thinking more along the lines of spark plug pooped itself.
Maybe ask him what the compression numbers were and a picture of your piston to prove something's wrong with it?
Old 02-23-2012, 11:27 AM
  #20259
Trav3480's Avatar
Current plan is to hire shipping company and ship it back to phoenix then repair it here..... SOOO who is down for possible rebuild
Old 02-23-2012, 11:45 AM
  #20260
SCcobaltSS's Avatar
I was going to say ask for the compression numbers. Other than plug or coil pack shitting out it seems weird. You said you didnt hear knock or anything... Just doesnt add up. I could maybe see the damage happened WOT and was holding on until then but you stated to me your AFR was 11.3 (which we did for safety) so that doesnt add up either.
Old 02-23-2012, 12:13 PM
  #20261
IonNinja's Avatar
Blown headgasket?
Damn that would suck ***** to break down in another state
Old 02-23-2012, 12:21 PM
  #20262
Trav3480's Avatar
yea.. not fun expirence...... I wasnt WoT, cruising at 65-70 5th gear , went uphill , just got off I-5 in Cali.. lost some speed, downshifted to 4th , Cel popped on and flashed , WB pegged 10:3 or so and stayed until I pulled over, then car died. restarted , slight rev, white smoke. turned off and stayed off. I didnt hear knock, but music was up and GF and I were talking , plus her dog in back seat so who knows, maybe it did and I just missed it. ran 91Oct Cheveron Cali gas entire way when possible. did have few stops of Mobile and Circle K I think . Entire trip was to be almost 1300 miles total. I did about 500 of it before it poped.
EDIT: 11:3 was under normal driving if I did WoT in Cali. didnt do much of it since had girl and dog in car but during 3rd and 4th gear runs would hold about 11:2 -11:3
Old 02-23-2012, 12:50 PM
  #20263
SCcobaltSS's Avatar
11.3 was under normal driving too?
Old 02-23-2012, 12:51 PM
  #20264
Trav3480's Avatar
11:3 was under flat ground WoT, normal cruising was bewteen around 13:5 and like 14:9.. u know how my car never ran constant AFR's
Old 02-23-2012, 12:58 PM
  #20265
SlowCobaltSS's Avatar
Why dont u rent a uhaul truck and trailer and go get the car yourself? , Hiring a shipping company will be alot more money
Old 02-23-2012, 01:03 PM
  #20266
Trav3480's Avatar
I would, but dont have a truck avail, plus never towed a car myself.. Driving expense to Cali at its location then gas expense and everything else just rather spend couple extra hundred to have it delievered. $595.00 is shipping fee with open truck
  #20267
SCcobaltSS's Avatar
AH ok I was scared for a minute if it was 11.3 just cruising. I was going to say there is something wrong right there!
This is a good idea. will save like 300$. Trailer is 50 a day I know that, go a couple before for my car.
Old 02-23-2012, 01:05 PM
  #20268
SCcobaltSS's Avatar
You can get uhaul trucks.
Old 02-23-2012, 02:03 PM
  #20269
smthomas556's Avatar
https://www.cobaltss.net/forums/tuni...thread-272204/
You going to go defend you 4.8 60-100 time that Brett posted! People are saying that they got 4.4-4.6's.
Old 02-23-2012, 03:17 PM
  #20270
SCcobaltSS's Avatar
Not too worried about it. Dont really have to prove anything. haha 4.8 **** air vs 4.4 in mine shaft air. ( stole your line)
Old 02-23-2012, 04:30 PM
  #20271
evofire's Avatar
just registered the car, and ordered my new plate.... BLWNECO
Old 02-23-2012, 04:53 PM
  #20272
08ssedan's Avatar
Everyones car is brokeded
Old 02-23-2012, 05:06 PM
  #20273
1LowLS's Avatar
I have a project on my car starting today/night.Anyone is free to come hang out while I do werk son!!
Check this **** out Tyler!!!!At the autozone across the street from me.I looked for him and couldn't find him
Old 02-23-2012, 05:08 PM
  #20274
You Blew Neco?! He was telling me that some guy gave him a good blowy last week...
Just messing man, You know I <3 you, no homo.
HOLY **** STEVE I LOVE YOU... homo...
Oh this is glorious... The things I will do
Old 02-23-2012, 05:10 PM
  #20275
evofire's Avatar
Steve what is your project?
Quick Reply: Arizona BS Thread
