Arizona BS Thread
what size is your inlet.I'll swap you straight up if you want.Mines a LSJ muffler.
and my retros are ebay retros haha.G3 projectors,they look ok but cutoff is terrible and the bi xenon works when it wants to haha
Haha Jerry^^^
I keep telling everyone my cars a factory freak when they think they can do the same mods I have and run the exact trap and ET I run.I dont know why my car runs as well as it does but it always has since birth.
Stephen:My trick for decent 60's on street tires is launch at 2200 rpm,all through out 1st gear, do not surpass 50% throttle.once you are out of 1st gear and in 2nd,hammer it.should net you a decent 60'.Also air down your tires and do a real nice burnout to clean off the tires and to warm em up a bit.Should get you into the low 14's atleast.
What Rpm do you shift at into 2nd and into 3rd?
I shift every gear at 7300. i touch 4th gear for the last 3-400 feet.Highest trap to date is 106
you gotta work on the shifts too.Make them lightning fast.
I have 6 forward gears too!!!1st,2nd,3rd,4th,5th,and open door and push gear.lmao and I forgot about neutral so I have 7 positions to put it in
that sounds so wrong,but so right
Hum. 7300. you Hp tuned or trifecta?
