Arizona BS Thread
Ya I want them, I'm just trying to think I'm not sure I can roll with them as low as he has them cuz my drive way is on a slant with the hump in the front lol And my exhaust is huge over the axle, how did it work for you Brandon?
Lol youre gonna wanna take them off after a week knowing you. Haha
My exhaust was fine and you will definitely need to change some driving habits, or just raise up the coils a little bit.
Not gonna go below 400 and yes i would need stock struts + whatever springs. If you wanna remove the ksports and put the stock ones back on thats fine but im not doing it for you
I actually have less scraping than i did when i had the ssc because of the rake with those springs. I can drive straight off my driveway at the ride height its currently set.
Nice ya I'm not taking off the springs either haha, well Ill have money sometime soon I'll let you know if you still have them
So I popped the hood this evening.
To get the tensioner and all the components (ie new chain, gaskets, etc) looking at $266 which is cost.
I really hope its just the tensioner and I didn't break anything else. I don't have the coin to build a forged motor.
Turns out i am an idiot lol.
It's the ac actuator for the air circulation that is making the ticking.
Still need to do some TLC with the car figure our the oil blowback, I have a little coolant leak and finally check PVC inside the valve cover
ZZP 82# springs and retainers.Thanx to CED for the cam gear bolts and balancer bolt.pistons and rings are put together.waiting for rod bearings and head studs to arrive along with valves.
Ok so I fund a 2.9 and a 3.0 pulley on craigslist for 30 dollars a piece used. Is this a good deal? And what would I have to do for supporting mods to run one of these pulleys?
oh and a 50 shot
