Arizona BS Thread
Which employee did you talk to lol.I was specifically told i would lose power from rights much increased over lap.but hey you want to be the test monkey, go for it.i won't waste my money on less power lol
any of the blower guys on here running any type of phenolic spacers? if so how do you like them, if not, look here:
Overkill Engineering Motorsports- Phenolic Spacer Blow Out SALE!!! - Performance Forum - j-body.org - the jbody organization
http://www.j-body.org/forums/read.ph...72515&t=172515
they are supposed to lower temps 10-12 degrees. I just ordered the one for between the blower and manifold.
So took a drive to Payson last night just for **** and giggles. Topped off with e85 (3 gallons) before heading up there, and played hard hard hard on the drive up there. The ratio, if it is indeed true E85, and the E10 that my premuim is would have been about E21 after being mixed. Never ever saw more then 1.8 degrees of KR. Played even harder on the way back, and never saw more then 1.5. Also, IAT's were spectacular up there. 102-105 while cruising at 75ish til we got to about 10 miles north of Ft McDowell. I love that drive.
Also go pulled over and given a written warning for going 72 in a 65.
the mixture i was on according to some online calculator larry used was E21. or 21%. AFR's were still good. 11.2-11.6 at WOT in 4th gear all the way to the 108 MPH limit i have. And it was pulling hard!!!!!
Product Review: O.E.M. phenolic m62 spacer - Boost Forum - j-body.org - the jbody organization
Hopefully you get your spacer before 8/3...if its worthwhile I may pick one up since its only $40
