South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 10-20-2012, 01:38 PM
  #23301
Tundraboarder666's Avatar
Would still need my car put back together... Rather go on a cruise before going to a dyno though.
Old 10-20-2012, 06:01 PM
  #23302
IonNinja's Avatar
Wideband gauges super cheap!
Innovate Motorsports 3844 Digital MTX L Wideband afr Gauge Kit | eBay
Old 10-20-2012, 07:02 PM
  #23303
JetBlackSS's Avatar
Any of the Tucson peeps gonna be at Hotrods tonight?
Old 10-20-2012, 07:32 PM
  #23304
1LowLS's Avatar
What's poppin tonight?I'm bored as fack!
Old 10-21-2012, 12:22 PM
  #23305
Tomtwtwtw's Avatar
Originally Posted by FF_ace
Do I need to put another dyno meet together?
Yes! But not till I get my car back...pretty sure this little Sentra rental won't win any awards.
Old 10-22-2012, 12:19 PM
  #23306
BigSid81's Avatar
It's always nice to get in the cobalt to go to work on a Monday morning to find the cel on, and engine power reduced message in my face.
Old 10-22-2012, 12:36 PM
  #23307
SCcobaltSS's Avatar
that blows... why is it on?
Old 10-22-2012, 01:37 PM
  #23308
1LowLS's Avatar
Well I am phoneless until I can afford a new one.It wouldn't turn on so I threw it as hard a s I could at the ground.Piece of **** android.Smart phone my fkn ass!
Old 10-22-2012, 01:41 PM
  #23309
SlowCobaltSS's Avatar
sorry it just sounded funny as hell thinking about it
Old 10-22-2012, 02:43 PM
  #23310
1LowLS's Avatar
Quoting myself ftw. Nick(FFace),PM me on here when you get your stuff lined up.
Old 10-22-2012, 03:35 PM
  #23311
BigSid81's Avatar
I didn't read the code, pretty sure it's because I took the cat off, and don't have a tune. I have a defouler on it, but I was doing some spirited driving last night. Just cleared the code, and it runs fine now....luckily.
Old 10-22-2012, 03:42 PM
  #23312
1LowLS's Avatar
P0420 will not induce EPR mode.P0420 is what you get when you pull the cat off without the tune.There is another isssue with you car causing EPR.
Old 10-22-2012, 04:14 PM
  #23313
06blackbalt's Avatar
what codes were they, could be possible throttle body issue, my car went limp when throttle body was going out, you can clear it but it will just happen again
Old 10-22-2012, 04:17 PM
  #23314
SCcobaltSS's Avatar
As 1LowLS said above, a cat code wont cause this. Usually this happens when a key sensor/equipment fails..
Old 10-22-2012, 06:18 PM
  #23315
ive had that code before... cleared it 50 times and eventually never came back. think it had something to do with the hpt software.
Old 10-22-2012, 06:57 PM
  #23316
BigSid81's Avatar
It ran good this morning from east mease to north phx, about to go home...hopefully I make it!
Old 10-24-2012, 02:43 PM
  #23317
2007 Chevrolet Cobalt SS
OMG RWD AND AUTOMATIC!!!! YES!
Old 10-24-2012, 02:59 PM
  #23318
SCcobaltSS's Avatar
Yes, remember it was because you were showing PSI . I got it to stop by changing diagnostic stuff. His is different I would guess.
I have seen one auto SS/SC in person.... and a handful of RWD...
Old 10-24-2012, 03:10 PM
  #23319
I was showing PSI? que?
Now I'm really not sure what route I will be going with the car...
Got the quote from ZZP down to 11k taking out the trans brake, LSD, their converter, and their 1" chain...
However he quoted me with this:
"If you make a lot of power, you need a very expensive converter to harness the power efficiently. At 450whp, a standard converter would work fine. We would just have to match it with your turbo.
The 7/8" chain will hold up to 400 ft lbs just fine, but if you build a race engine to run at 30psi and 500+ ft lbs, then it will stretch over time."
Idk I guess I'm just worried I'm already pushing the limits on these... And then let's say I do spend the extra money to put in their converter then I would be losing lock up.... Not gonna be driving freeway at 3500RPMs... no thanks.
And if I get the other chain then I lose the ability of overdrive...
I just can't win with this ****.
So right now I'm sitting with take the risk and just get the basic stuff in there since I lose so much otherwise... highest Chris and I could probably get this thing to turn out would be around 400WHP 380WTQ I'm guessing... So i think I should be fine on the limitations, just a little worried.
Or I just rebuild this stupid trans again go down to 8 PSI cut the E85 and save my money up for a used C7 base model in a few years.
Ideas comments concerns phobias...
Old 10-24-2012, 03:50 PM
  #23320
1LowLS's Avatar
Your turbo is only capable of 400-450hp I believe efficiently.SO I think you would be perfectly fine with ZZP's stuff.I honestly don't think your torque is close to limit.It's up there in the 3 hundo's for sure though.Think about this...If you drop to 8psi,do you really want to get beat by me again? There's your motivation.
Old 10-24-2012, 04:11 PM
  #23321
FF_ace's Avatar
Just buy my car lol
But just rebuild it cut out e85 and run 8psi
Old 10-24-2012, 04:12 PM
  #23322
Yeah...
You have no idea how incredibly sad that was because that actually did motivate me a lot... lol
Old 10-24-2012, 04:14 PM
  #23323
Just buy my car lol
I would buy your car if it were victory red lol
That color really turns me off for some reason though... no offense meant or anything.
Would definitely have the fastest cobalt in AZ though.
You keep doing stuff to it and making it more expensive though! lol
Old 10-24-2012, 04:19 PM
  #23324
morgielouwho's Avatar
dont shoot me down for asking a dumb question... does the cooler weather have a factor in why my lean code has come back.... it was gone forever and it is somehow back now all the time. p0171 i believe. (if i remember correctly)
Old 10-24-2012, 04:55 PM
  #23325
1LowLS's Avatar
quite possibly from winter blend fuel???maybe?
Quick Reply: Arizona BS Thread
