South Mountain UT, AZ, NM, and CO
Arizona BS Thread
Old 10-24-2012, 05:12 PM
  #23326
08ssedan's Avatar
Free trans rebuild and new tcase along with free clutch install weoooooooooo
i *** widdit
Old 10-24-2012, 06:56 PM
  #23327
1LowLS's Avatar
Noice!!!^^^ Glad she's gettin fixed up
Old 10-24-2012, 07:25 PM
  #23328
Mikey D's Avatar
MyFineWheels 1st Annual Car Show Mesa, Arizona
Local show
Old 10-24-2012, 07:28 PM
  #23329
SCcobaltSS's Avatar
Originally Posted by morgielouwho
dont shoot me down for asking a dumb question... does the cooler weather have a factor in why my lean code has come back.... it was gone forever and it is somehow back now all the time. p0171 i believe. (if i remember correctly)
Depends how off the trims were before it got colder. Colder air is more dense so it can become more lean. I believe the trims have to be -/+ 15 to 20 tp throw a lean code. Seems you need a custom tune. Its risky going WOT with a lean code because if the lower cells of the MAF are lean more than likely the upper are too and that is no good for the pistons.
Old 10-24-2012, 07:45 PM
  #23330
Mikey D's Avatar
Clean MAF, check filter, dust from any summer storm could have finally worked its way through.
Old 10-24-2012, 08:30 PM
  #23331
Tomtwtwtw's Avatar
9500 in damage to my car! Surprised they're even going to fix it.
Old 10-24-2012, 08:54 PM
  #23332
1LowLS's Avatar
would have to be more than the value of your car to be totaled,which I highly doubt your bluebook is $9500
Old 10-24-2012, 09:48 PM
  #23333
Tomtwtwtw's Avatar
KBB trade-in is 9252 good, 9777 very good. I'd say it was a close call at least. Still, I'd rather have it back than shop for a new car.
Old 10-24-2012, 11:28 PM
  #23334
1LowLS's Avatar
I don't think they go off trade in...do they?Fack trade in on my car would be like 5 dollars!
Old 10-25-2012, 04:53 AM
  #23335
Tundraboarder666's Avatar
Yeah they do go off of what trade in of KBB would be. Which would suck a lot if one of us was LS guys was boned like he was...
Old 10-25-2012, 12:40 PM
  #23336
Tomtwtwtw's Avatar
A couple people told me they may also go off wholesale, which I think is even lower than trade in. About 1/3 of it is coming from the trunk tub (1k part, 26+ hrs labor). They also need to replace both front and rear bumpers, braces, a headlight, battery and a few misc. other parts. No frame damage, no suspension damage, no damage within engine bay...so despite the high total the car is actually in good shape between the braces. Hell, considering I've been backed into a couple times, my rear bumper will actually come out looking better than before!
Old 10-25-2012, 06:43 PM
  #23337
evofire's Avatar
ive been told they go off private party....thats what mine did.
Old 10-25-2012, 08:40 PM
  #23338
FF_ace's Avatar
Well new 3 bar progressive meth kit is in.... Should have the stainless steel lines hooked up tomorrow
Old 10-26-2012, 10:20 AM
  #23339
morgielouwho's Avatar
thanks guys..
Old 10-26-2012, 11:02 AM
  #23340
FF_ace's Avatar
I have a partial progressive devilsown meth kit up for grabs... 2.5 bar controller, 4 qt tank, check valve, and nozzel holder, 3gph nozzel. All u need is new lines and a pump
Old 10-26-2012, 12:22 PM
  #23341
1LowLS's Avatar
Did a reflash yesterday.No added timing yet but AFR's seem to be in check now.low rpm starts around 13.2:1 and richen up to 12.5 towards mid-top end.Now just got throw more timing into it.Clutch will be coming soon at this rate
Old 10-26-2012, 01:14 PM
  #23342
SCcobaltSS's Avatar
What does it end at?
Old 10-26-2012, 02:43 PM
  #23343
1LowLS's Avatar
right around 11.8-11.9:1.Hard to catch it as I am watching the tach
Old 10-26-2012, 07:11 PM
  #23344
Yeah it seemed to be low 12's most the time
Old 10-26-2012, 11:15 PM
  #23345
1LowLS's Avatar
I was seeing 11.9 today at redline.Csn you email him to make sure the timing tables are smooth and gradually go up so there are no spikes.Seems like timing wants to spike.
Old 10-27-2012, 01:51 PM
  #23346
IonNinja's Avatar
Hahn muffler is on
Mucho better
Old 10-30-2012, 03:52 PM
  #23347
Mikey D's Avatar
Okay.... I am going to start saving for a tune... Whose best, how does it work, what gains, and if the dealer were to flash it is it free to have it re-tuned?
Old 10-31-2012, 12:52 AM
  #23348
1LowLS's Avatar
So the V10 Ram had a constant misfire.No codes.So I allowed the spark plugs to tell me what cylinder was not firing.#2 plug was drenched in fuel and looked brand new,meaning no combustion was taking place.Checked spark and all was good(got zapped a hundred times lol).Continued on to compression which was 0 psi.I was like .So today I started breaking into her more.Pulled the intake manifold off so I could pull bank 2 valve cover off.Pulled the cover off and found this.
The rocker bolt snapped in half causing the pushrod to jump out.Drilled through the middle of the broken bolt and hit it with a easy out which came out like butter.Put in a hardened grade 8 bolt,cleaned out the intake manifold and throttle body which were gunked up pretty good and she's running on all 10 again.The torque in this thing is impressive for a 1st gen 8.0 V10.This job took me all day from lack of room to work with lol.Fun times!!!
Old 10-31-2012, 01:21 AM
  #23349
evofire's Avatar
good work steve! did you get paid for this?
Old 10-31-2012, 02:15 AM
  #23350
1LowLS's Avatar
Doing an oil change on it tomorrow then I will take payment upon delivery.
Quick Reply: Arizona BS Thread
