Lookin' for a CAI
fujita has better numbers http://www.f5air.com/images/dyno/ca1...obalt%20ss.GIF and as far as fitment goes other than cutting the piping to the filter it was just really tight but it still fit without bending anyt brakelines
yes i did. like i said its really tight but it fits. do i reccomend getting it probably not just cause of it being a bitch to install. but if youre able to deal with it and not get mad like me then its great once its in.
Well thats cool that it fit for you. Just check it from time to time to make sure it doesnt rub on the brake lines, or anywhere else for that matter. Since it's an aluminum intake, it's more likely to get a hole rubbed through. Good luck with it
yeah thats the reason y i had to get a RAW after my injen intake got a hole in it
I used to have the RAW intake on my 07'. It didn't fit the best. Very tight, and I had to slightly bend the brake lines down to get it to fit correctly. Other than those issues it was a great intake, and I miss it, because it was the only RAW intake I knew of that was powder coated in Gunmetal.
http://www.ottperformance.com/store/...ake-10p919.htm
take it from a local man, i've had like 3 intakes, this would be by far the best one.
I would argue that there is another intake on the market that is just as good, if not better (being a 1-piece 3" T304 design).
http://www.rdfabs.com/20ecocobsssc_caint.php
#36
The OTTP intake is a great intake, no doubt.
#38
Well, you are correct, I have heard that some can get it to fit. With my luck I'm one of the 07's that the RDFABS intake will not work on. I was very close to buying it last Spring, but went with the Rebel because of a group buy.
#40
#44
#47
#49
and with my luck.. ill have a cop ask my to pop my hood
