3rd GEN Projectors $190 with anti glare mod
#276
First off did you get HID's with your light if so did you order the drl module with your lights, cause if not it will cause that problem when the daytime running lights are active. If you didn't purchase the drl module try pulling your DRL fuse and see if that fixes your problem. I hope this helps.
Edit: this is only for 07 and newer that use the low beams for DRL's. 05-06 use the running lights as the DRL's and don't seem to have this problem.
#277
If the lights only turn on after a few times of turning it on and off a few times it is almost always a loose connection coming from a connector. I would double check the wires that go into the connectors and the grounds inside the housing.
#278
I haven't read all 16 pages of this thread and I'm still a noob with the Cobalt, but what exactly does the anti glare mod consist of? Also has anyone retrofitted good lenses like TSX or S2000 lenses into the 3rd gen housings?
#279
i think the reason there not turning on is because the ballast is not getting a good charge, i dont know ANYTHING about hid in cars, but hid is like a flourescent bulb, if the ballast starts going bad, you gotta flip your light switch a few times to get a good charge for the light to come on, if both lights are off one balast then that makes no sense, but if its a balast for each one i would say theres either a short in the balast or its a bad balast.... \o:
#280
#282
So I have 50W ballasts with the plug and play harness for my HID headlghts. I have noticed when they are on, my radio reception goes down by like maybe 40%. a significant amount. I was wondering if getting relays for them would solve this issue. I didn't get the relays because somebody.....nameless....told me I didn't need them.
I was also hoping that if I did go the relay route then hope beyond hope maybe my right headlight would also maybe get its act together. I have to replace some bulbs and aim them anyways so I will double check the wire connections again just in case.
Any specific wire connections (colors? pictures?) that I should be checking again?
#283
ok we installed them according to the "how to" on page 15. we have the headlights in and they look sexy. im only havening one problem. the driver side outer halo isnt lihting up any suggestions? all of the connections are good. here are some pics.
thanks for any help i get
#287
Questions are as follows:
1) Do you get a set of halogen H1's for the high beams with either the headlight kit or combo w/ HID's.
2) How hard is to replace the LED's in the halos/three little ones, because I plan on having these on all the time as a weak DRL.
3) Also considering adding my own 12V+ to the halogen high beams to make them DRL's (relayed from pin 87a of a relay connected to the low beam HID's)... what do the wires coming out of the back of these look like? Can I do what I please with the high beam wire?
#288
I just got my set in and aimed and they look great. I have two problems though.
1. The passenger side beam is a LOT brighter than the driver side beam. Think it's the bulb or the ballast?
2. The driver side housing doesn't fit well. It fits very well to the corner at the fender, but there is a gap between the fascia near the grill and the housing that I can fit my pinky through. Has anyone been successful at adjusting the fit on the headlamp assemblies?
I'll get some pictures when it's dark out.
#289
2) The LEDs are not hard to replace, the halo's require you opening up the headlight to replace them. But making them your DRL should not be hard.
3) There are 4 wires coming out of the of the bulb, the smaller black and red wire are the high beam wires. But cutting into them will void the warranty on the bulbs.
If that is not the case, swap the ballast around, drivers side to passenger side and vice versa and see if the problem follows the ballast and just let us know from there partner, we'll take care of you
#294
they dont come in red or blue unless when you buy them you tell them to do that and it will cost more money they only come in white with 3 bluish L.E.D's
