Aeroforce Interceptor group buy?
#153
did u get it tommy?
im not sure what to do.......if it did come with the silver ring i was just going to paint it red to match the seats.......if i paint the stock black ring on the interceptor do u think it would look as good?
#159
1.07boosteg5, CN, Single
2.1AJeremyD, PT, Single
3.TommypSS/TC, CN, Dual
4.BPacak, CN, Single
5.paintballerr78, CN, Single
6. 06_sic_ss, PT, Single
7. Dayta, PT, Single
8. 2010SS, CN, Dual
9. Gotboost?17, CN, Single
10. skullz666, cn, dual
11. dcobaltss, CN single
I want one too whats the price for it?
8. 2010SS, CN, Dual
#160
READ post ONE
<--------------Css! I do NOT work for OTTP, Please send your questions to Josh@ottp
Thanks
Moderator Notice: The group buy is underway! Please make your purchase on OTTP's website, and use the coupon code listed below to receive the group buy pricing. The group buy is back up again, this time until the 22nd, so get your orders in!
Heres the info
Aeroforce Technology Inc | Products - Interceptor
05-07 Cobalt 2.0L (PT)
08+ Cobalt 2.0L (CN)
05+ Cobalt 2.2L & 2.4L (CN)
If you dont know what it does heres some of the data it can pull off the car in real time
-Dozens of critical parameters available for every supported vehicle. Can view 2 to 8 at a time in large, easy to read numbers without touching the gauge.
-Record and play back data on gauge, no need for laptop or other device
-Accepts 2 additional sensors without requiring any additional equipment unlike other copycat products. Allows you to read such things as air/fuel ratio, EGT temps, etc. that are not on the vehicle from the factory.
-High intensity warning lights can be programmed to indicate unsafe vehicle operating conditions.
-Integrated shift lights.
-Available in numerous configurations allowing you to match or customize your dash!
Displays the following information:
RPM
MPH
Intake Air Temperature (post Intercooler)
Ambient Air Temperature (pre Intercooler)
Engine Coolant Temperature
Exhaust Gas Temperature (PCM Calculated)
Transmission Temp. (auto trans)
Manifold Pressure (vacuum/boost) displayed in PSI
Fuel Temperature
Battery Voltage
Battery Temp
Injector Pulse Width in msec.
Injector Duty Cycle (%)
Air Flow Rate into engine
Long Term Fuel Trim
Short Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Fuel Status (open/closed loop)
Wastegate Solenoid Duty Cycle (%)
Knock Retard
Knock Sensor Raw Voltage
Throttle Position Percentage
Throttle Position Sensor Raw Volts
Calculated Net Horsepower
Engine Load
Transmission Slip
Current Transmission Gear
Torque Delivered to Transmission
Torque Converter lockup status
Brake pressure
Brake Booster Travel
Steering Angle
Non-driven Wheel Speed
Lateral G's
Yaw
Fuel economy (instantaneous and average)
P-ratio - pressure ratio MAP/Barometer
Thanks
RPM
MPH
Fuel Temperature
Battery Voltage
Battery Temp
Long Term Fuel Trim
O2 Sensor Voltage
Barometric Pressure
Ignition Advance
Base Spark
PCM Spark Adjust
Knock Retard
Engine Load
Transmission Slip
Brake pressure
Steering Angle
Lateral G's
Yaw
#172
Sorry guys, I'm new to this site... It's kind of confusing. Is this group buy still going on? I'm slowly trying to accumulate all the things I need for a bigger turbo
#173
AWD > FWD
https://www.cobaltss.net/forums/supp...up-buy-259761/
