Groupbuy On Retrofits, kits and hids? Post Here
Old 08-20-2011 | 01:49 AM
  #351
keiserX13's Avatar
Originally Posted by nobody2u
Okay, I was gonna say... it wouldn't make sense for the sale price to stand. Sucks for me though.
but you can still get kits of the web site BUYHIDS.COM HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light
Old 08-20-2011 | 05:13 PM
  #352
sponge14's Avatar
Okay, I'm having a hard time installing the retrofit projectors into the headlight. I have everything apart now and I'm trying to figure out how to mount the projector to the headlight. The instructions on the BuyHID's site are not matching up to what I have. I have the wire threaded into the hole where the reflector was mounted, and I have the projectors in the headlight. There is a nut with a bunch of notches, and then a bunch of odd looking spacers and washers in a parts bag. I don't know what order to put the spacers, washers, nuts, etc to mount the projector.
BuyHID doesn't have a contact phone number for help, is there anyone that has contact info for mkulrey13, or keiserX13?
Oh yeah, and I don't understand how the halo's mount to the projector or how to wire them. I thought they would be part of the projector kit but they are separate pieces.
Old 08-20-2011 | 05:20 PM
  #353
mkulrey13's Avatar
you can PM US! but ill answer your question here
Your parts bag, you only use the thin metal washer and thin rubber gasket. Throw away the large metal and rubber peice. Now, OEM headlights, if you look on the back.. It has fins, they need to be sanded down so there flush. You ONLY need to do this on the back side. If you slide the metal washer into the back side of the reflector it only goes so far and then hits these fins. Once you sand down those fins take the small rubber gasket and put it on the threaded part of the projector so its all the way on, now insert projector into bulb hole. Take the metal washer and slide it on, The grove part of the projector faces up. Now take the nut and spin it on. Needle nose pliers are easiest ive down to tighen the nut once your fingers cannot do it anymore. a trick i do to make the washer go on is before you insert the projector, take the washer and slide it on as far as it will go and wiggle it till its all the way on then take it off. This will shave any little parts of metal in the way. Blow on it to clear the shavings before installing.
BTW if you noticed the instructions on the website are for the old projectors..
Any help, HIDPlanet.com has great info!
Old 08-20-2011 | 05:44 PM
  #354
keiserX13's Avatar
we should make a new how to then
Old 08-20-2011 | 05:53 PM
  #355
sponge14's Avatar
If I knew it was going to be different, I would have taken pictures.....
I will say this, the kit looks great so far, quality pieces for sure! Once I get over my installation hick-ups (which is just my inexperience with this...) I'm sure it will be great!
Old 08-20-2011 | 06:07 PM
  #356
sponge14's Avatar
Okay I got the mounting done.... How do I attach the Halos, and where do they go? They are mounted on the outside of the projector shroud, right? What do you recommend mounting with?
Old 08-20-2011 | 06:21 PM
  #357
keiserX13's Avatar
yes the standard location is on the outside of the shroud
you can use thin wire or fishing line to hold it in place
Old 08-20-2011 | 06:28 PM
  #358
sponge14's Avatar
I should have bought the pre-made's... lol.
Old 08-20-2011 | 06:32 PM
  #359
keiserX13's Avatar
thats what i did
Old 08-20-2011 | 08:16 PM
  #360
royce777's Avatar
can i get a DIY kit sstill
Old 08-20-2011 | 08:54 PM
  #361
mkulrey13's Avatar
Yes PM us and well send you an invoice. Price will be a bit higher though.
Old 08-21-2011 | 05:21 PM
  #362
CTFinestTurbo's Avatar
Hey hows it looking on the retro headlight build? No rush just trying to see how everything is coming along
Old 08-21-2011 | 08:33 PM
  #363
mkulrey13's Avatar
Im doing 9-10 at a time. I work 40 hours a week and have a wife. Its coming along
Old 08-21-2011 | 08:40 PM
  #364
keiserX13's Avatar
whats the wife have to do with anything
Old 08-21-2011 | 09:04 PM
  #365
mkulrey13's Avatar
^ you have a wife and your not even married!
Old 08-21-2011 | 09:07 PM
  #366
keiserX13's Avatar
shut it!
Old 08-21-2011 | 10:43 PM
  #367
padlock's Avatar
just taking a couple pictures of what the back of the reflector looks like & the parts you use would help immensely for us noobs! just saying
Old 08-23-2011 | 06:28 AM
  #368
mkulrey13's Avatar
Bump, Factory has shipped my order. get ready people!
Old 08-23-2011 | 08:09 AM
  #369
DWoods54's Avatar
Yesss!
Old 08-23-2011 | 10:28 AM
  #370
RKRamos's Avatar
WWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWWOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOO!! can't wait!
Old 08-23-2011 | 11:59 AM
  #371
NiceBaltSS's Avatar
Hell yesssssss!!!!
Old 08-23-2011 | 12:11 PM
  #372
mine are for sale as soon as they come in lol
Old 08-23-2011 | 01:59 PM
  #373
keiserX13's Avatar
why?
Old 08-23-2011 | 03:03 PM
  #374
sold retrofits, no point running hids in fogs. will look silly
Old 08-23-2011 | 04:14 PM
  #375
keiserX13's Avatar
get HID headlights
