Groupbuy On Retrofits, kits and hids? Post Here
Old 10-08-2011 | 10:11 PM
  #576
keiserX13's Avatar
Originally Posted by D-mac
Wish to order LEDs
Car LED Bulbs
Or PM me or mkulrey
Old 10-11-2011 | 11:04 AM
  #577
NiceBaltSS's Avatar
Rob & Devin, both yours will ship on Monday!
Should we have gotten a tracking number via UPS or anything like that? Just so I can know when I need to be home and what not?!
Old 10-11-2011 | 11:11 AM
  #578
keiserX13's Avatar
PM me or mkulrey your order number and we can get you it
Old 10-11-2011 | 11:15 AM
  #579
NiceBaltSS's Avatar
^ You have a PM sir....... thank you! ^
Old 10-11-2011 | 11:18 AM
  #580
keiserX13's Avatar
You do also!
Old 10-11-2011 | 02:16 PM
  #581
DWoods54's Avatar
just checked this and saw i can get a tracking number! ill be finding my order number very quick and PMing you sir! keiser that is, since i bothered mkulrey enough
Old 10-11-2011 | 03:13 PM
  #582
keiserX13's Avatar
you have a PM
Old 10-12-2011 | 01:05 AM
  #583
Tcobalt421's Avatar
i still cant get my retros to work, the blubs still wont lightup
Old 10-12-2011 | 01:47 PM
  #584
keiserX13's Avatar
have you double checked your connections
do you have solid grounds?
can you hear the relay click?
do your parking lights work?
Old 10-12-2011 | 04:19 PM
  #585
Tcobalt421's Avatar
^checked connections, relay does click over, have a good ground and i have the switchbacks and resistors working great, idk whats wrong ughghghg fml
Old 10-12-2011 | 06:40 PM
  #586
NiceBaltSS's Avatar
Woooo!!! UPS finally update my shipping page and my retros will be here on Friday!!!!
Old 10-12-2011 | 08:12 PM
  #587
Tcobalt421's Avatar
^lucky, at least urs will work
Old 10-12-2011 | 08:40 PM
  #588
sponge14's Avatar
Take it easy and check all of your connections. Keep in mind that the wiring note that came in the box for the harness is incorrect. What kit do you have?
It took me about 2 full weekends to get mine working right and aimed correctly. If you are like me and have never done this before, it's a bit confusing without having a good set of step by step instructions with correct wiring diagrams.
Old 10-12-2011 | 08:58 PM
  #589
mkulrey13's Avatar
Please check your connections. 99% of the time its connected wrong. Ive swapped your pins but just to make sure, it should be Orange/Black/Blue on the 9007 plug. Also the plug that connects to your ballast should be the Orange/Black wires. The one that connects to your Highbeam shutter is Blue/Black. Most common problem is users are using the headlight bracket for the GND which does not work on most cars. Try the fender bolt.
Old 10-12-2011 | 09:19 PM
  #590
Tcobalt421's Avatar
i shall keep trying thanks for the advice but all the connections are in the right place as you just stated and relay works fine idk what it could be, its grounded tight as hell
Old 10-12-2011 | 09:21 PM
  #591
mkulrey13's Avatar
Make sure your ballasts are not plugged in backwards.
Old 10-12-2011 | 09:53 PM
  #592
LS6Rally's Avatar
^ thats what i was going to suggest, its very easy to plug it in backwards.
Old 10-15-2011 | 07:28 PM
  #593
sponge14's Avatar
I've had 2 issues that I've been noticing. First is when I turn the brights on to where they stay on, they initially come on very bright and then they dim down. I've had other people in the car who have noticed this too.
My other issue is that if I start the car and the lights are on, the drivers side flashes in the same timing as the motor turning over.
Any ideas?
Old 10-15-2011 | 09:12 PM
  #594
mkulrey13's Avatar
Your high beam thing seems to be common with the new morimoto harness's. If you would like, I can email them and see if they would swap out your new harness with there old style. You would have to re-crimp the connectors for the high beam wires. I was told by them that after there used for a bit that weird thing goes away.
As for the flashing, Prob the voltage drop when you turn the car over. You have removed your DRL fuse correct?
Old 10-15-2011 | 10:36 PM
  #595
sponge14's Avatar
Damn that's a lot of work for the brights, but it may be worth it... I guess you probably don't know, but would the brights on the old harness stay that real bright color they are at first, or do they come on at the dim level that mine settle out at? I'm curious as to what can cause this issue with the harness, I mean it's all just a bunch of wires and 2 relays? They say that the issue goes away after a while, that would lead me to think that it is the relays?
Yeah the DRL is out. This only happens when the car is in a dark area, so the lights are on. As long as it's not indicative of a dying ballast or bulb I don't really care.
Old 10-17-2011 | 08:28 PM
  #596
DWoods54's Avatar
alright, everything is in. fogs work. low beams work. high beams work. the only thing is the halos. but i still have the two tiny little white wires and im assuming thats the two wires for the halo. i read something about splicing white to brown and black to ground..but theres just two white wires. any help please!
Old 10-17-2011 | 08:38 PM
  #597
klutch814's Avatar
how much is a kit? i wanna get a pair of stockers and paint them and do this.. any pics of your kit installed?
Old 10-17-2011 | 08:41 PM
  #598
mkulrey13's Avatar
I believe i forgot to include the inverters was in such a rush. PM me your address ill get them out tomorrow.
Old 10-17-2011 | 08:42 PM
  #599
mkulrey13's Avatar
Pictures are on our website, BUYHIDS.COM HID Lights HID Kits Xenon Headlights Kit HID Headlight Kits HID Conversion Light
Old 10-17-2011 | 08:43 PM
  #600
mkulrey13's Avatar
Also HIDs when turned on are bright then dim but slowly get a tad brighter over a few secs. Just how they warm up. For some reason the harness on cobalts, makes the lights do this when switched to highs, I wouldnt worry about it much, If a ballast or bulb does fail, Just PM me and well replace it!
