Groupbuy On Retrofits, kits and hids? Post Here
Old 10-29-2011 | 04:36 PM
  #651
keiserX13's Avatar
Originally Posted by CmplXty
Whats the difference between all the different HID's on the BuyHID website? Like H1, H3 etc
The bulb size
Cobalts take 9007 for the headlights and H11 for the fog light
Headlights - 9007 HID Kit
Fog lights - H11 HID Kit
Old 10-29-2011 | 04:49 PM
  #652
CmplXty's Avatar
The bulb size
Ah ok thanks.
Old 10-31-2011 | 10:16 PM
  #653
1995chevy's Avatar
All harness's should be swapped before there shipped. I may have missed one who knows. make sure your high beam solinoid plug is connected to the blue/black wires. Also i also could have repinned your plug wrong. Take the plug that comes out the back of the headlight. Its a 9006 plug. With the notch facing up, black wire should be to the left, and red should be to the right. Also your PINs in your 9007 plug could be bent. Or it just may be your fuse for your high beams. I test each and every setup on my personal car before there shipped.
harness looks like how you described and the pic above and the fuses look good no breaks but we got hammered over the weekend so when its nice im gonna take them out and recheck all the connections make sure nothings pinched. but the lows work great. and im lookin at ur instructions over and over and in your halo pics the passenger side has a blue plug and i didnt have that the passenger plug on the head light is just hanging there??
Old 10-31-2011 | 10:42 PM
  #654
sponge14's Avatar
Yes, you only need to connect one blue OEM plug to the HID harness. Think about it this way, the harness doesn't need 2 sets of 'inputs' from the car, which is what the blue plug is.
Old 11-01-2011 | 12:24 AM
  #655
1995chevy's Avatar
Alright just making sure because the blue plug on the pass side is dangling and i wanted to make sure that wasn't the reason because of not completing a full circuit or something
Old 11-01-2011 | 12:36 AM
  #656
keiserX13's Avatar
nope
just tape it off so water doesn't get in a short anything out
Old 11-01-2011 | 08:25 AM
  #657
mkulrey13's Avatar
Did you check the plug as mentioned in my post?
Old 11-01-2011 | 09:53 AM
  #658
1995chevy's Avatar
hope these can help i just checked all the plugs and still nothing checked fuses with a check light and it lights
Old 11-01-2011 | 02:18 PM
  #659
1995chevy's Avatar
i feel that everything is right?? but hell if i know whats wrong....
Old 11-01-2011 | 09:34 PM
  #660
mkulrey13's Avatar
They look correct, just make sure the pins are not bent and are making a connection. Sometimes with the 9006 plugs, they will plug in fine but the pins will go behind the actually connector inside if that makes sence.
Old 11-02-2011 | 12:28 AM
  #661
1995chevy's Avatar
So if you push them to far together it may not work? I'll try Tom
Old 11-02-2011 | 01:41 PM
  #662
sponge14's Avatar
I've had an issue creep up on me here. I have noticed when the lights turn on, or are already on, that they are causing a LOT of interference in my radio, both AM and FM. I'm guessing the ground may not be good? This might also cause that strobe effect I see when the car starts with the lights on? If this sounds logical, I will get some sand paper and try to clean up that grounding post better...
Old 11-02-2011 | 01:42 PM
  #663
keiserX13's Avatar
what are you using for a ground?
Old 11-02-2011 | 01:53 PM
  #664
mkulrey13's Avatar
Radio and ballast issue is normal. Ive got that with my kit and Morimoto's kit.
Old 11-03-2011 | 01:53 PM
  #665
sponge14's Avatar
The post that is recommended in the installation instructions, the one behind the drivers side light.
Damn... What kind of voltage and amperage are these things running at to cause that kind of interference???
Old 11-03-2011 | 02:17 PM
  #666
1AJeremyD's Avatar
its more or less just having unshielded power like cars had back in the day for spark plug wires. Turn the radio onto a certain station and you could hear the engine ticking away. Its just power surging through the body. Not much you can really do other than invest in an ipod/cds lol
Old 11-10-2011 | 02:25 PM
  #667
mkulrey13's Avatar
Oscar yours ship today! Jeffery, yours are 50% done!
Old 11-10-2011 | 05:50 PM
  #668
CTFinestTurbo's Avatar
cant wait to install it....thank you for you hard work
Old 11-10-2011 | 06:03 PM
  #669
mkulrey13's Avatar
Thanks, Its hard finding time with work, wife whos prego and time to play MW3...
Old 11-10-2011 | 06:15 PM
  #670
lol yea i know how that goes especially here in ct right now where im still cleaning up all the branches and half trees that fell..
Old 11-10-2011 | 06:36 PM
  #671
1AJeremyD's Avatar
You end up loosing power where you were? My work only got power back on that friday (oct 4)
I can't seem to find any time for anything since im working from 8 to 8 practically lol
Old 11-10-2011 | 07:06 PM
  #672
Murdered SS's Avatar
Hey i've been noticing it for a while now but my passenger side headligh doesnt look lke the driver side. The driver side looks 8k but the other side looks normal no buish tint just oem. Is there a fix to that or do i need a new bulb. Also how much for a new bulb?
Old 11-10-2011 | 07:11 PM
  #673
mkulrey13's Avatar
Swap the bulbs around, COuld be a slight mm difference in the design causing the color to be different. usually its the spacing.
Old 11-10-2011 | 07:38 PM
  #674
Yea ok i will try that cause its been driving me nut lol. but if is not that how much would replacment bulb be?
Old 11-10-2011 | 07:54 PM
  #675
mkulrey13's Avatar
It would be warrantied most likely by TRS. Could also be a ballast.
