Retrofit Headlights, HID Kits, LED Bulb GROUPBUY! - BuyHIDs.com
#78
What is the purpose of the relay harness? I'm getting a 9006 set for my avalanche, and just need the low beams and how do I know if I need 35w or 55w?
This sale is perfect timing as my drivers side just went out
#84
#89
you can cancel my order with the facebook deal. thats a ripoff and not my fault if you can't get your coupon details right. nowheres on facebook did it say single hid, so as far as im concerned, its your own problem. And it really isn't quite right that you just send an email asking for more money without making some sort of deal with me. poor businessman skills.
#90
Normally the bulbs would get power through the car's wiring harness. The HID's draw more power than a stock bulb. The car's wiring can probably handle it, but it's not the best way. The relay harness connects directly to the battery post under the hood, and the ground on the body. It also hooks to the stock headlight harness, which is used only for the control of the lights. When you turn your lights on, the relays make the connection directly from the battery to the HID ballasts. The wires on the harness are MUCH thicker than the stock headlight wires. This saves both your car's wiring, and makes it easier for the ballasts to get the power they need to operate.
#91
PM guys with any questions! thanks for everyone who has purchased so far! if you have a preference on color for a decal please PM me your name and order number and color you would like! Standard is white.
#92
