Shift and brake boots group buy
Old 01-29-2010 | 10:52 PM
  #476
heres mine
Old 01-30-2010 | 12:19 AM
  #477
OriGinaL Condo's Avatar
Got mine yesterday. I'll have to post pics when its warm enough out to install it. And when I have time to work on something besides the vette
Old 01-30-2010 | 05:21 AM
  #478
JapEatr's Avatar
South Central *********
The boots have arrived but not the handle...hmmm NGA, what is expected delivery?
Name is Steven Hooser, but for some reason the email is not linking it to the order
Old 01-30-2010 | 11:17 AM
  #479
smartmts123's Avatar
Just got mine and installed in 15 deg weather... the old boot was falling to pieces. everything fit great except the top part of the shift boot since i don't have the reverse lockout anymore... a little ziptie fixed that no problem. Thanks for the awesome group buy!
Old 01-30-2010 | 12:34 PM
  #480
buellfooll's Avatar
i got my car used so the tabs on the silver piece with the gear numbers was broken, it was glued on, so i have to glue it back.
the install for me sucked but it does look good, now my problem is the momo handle i put on and the button doesnt even make it out, so whats up with that?
i can still use my e brake but releasing it now is retarded
its annoying
regardless of my install being crap love the products
You have to be a little creative with the MOMO handle. A razor knife or, preferrably, Dremel tool will do it. You have to carve a little out of the plastic ring on the bottom of the handle so it slides down further on the ebrake lever. OR!! I SUPPOSE you could get even more creative and Dremel a little off the metal lever itself. OR a combination of BOTH so as not to remove too much from either one. If I had it to do again doing both is the way I would go. I also shaved down and shaped the button end of the handle so it fits INTO the MOMO handle just enough that the button extends out as far as it did stock. Good luck. Now all I need is the boots so I can put everything back together again.
Hint, hint, Redline!
Old 01-30-2010 | 05:40 PM
  #481
StyleandSpeed's Avatar
I like the ebrake cover very nice looking, do they have ferrari style shift gates available for our cars? Just think it will look a little sportier then the old shift boot, not that i mind, its just i would prefer.
Old 01-30-2010 | 06:11 PM
  #482
Sweetsandman's Avatar
its annoying
I had the same issue with my momo handle but I was able to solve the problem using a razor blade I just trimmed off a little of the rubber ending from thatpiece that still is on there and just shoved it down on there and now its perfect!!
Old 01-30-2010 | 08:45 PM
  #483
good idea, i did try to shave some of the ebrake handle at the bottom where the MOMO handle hits but it wasnt helpin much, i used a big file. so you guys are saying i can cut some of the inside of the Momo handle with a razor blade?
thanks for the helpful hints and suggestions, will probably do one of them
Old 01-30-2010 | 09:06 PM
  #484
No no no not the MOMO handle just the ebrake..I used a razor and trimmed the big lasticy rubber part that sticks out on the passenger side as well as some of the bottom (including the little tab that's down there) once I trimmed those things down it went on snug and I was able to get it perfect. Now I just gotta wait for my Hurst STS to get here...
Old 01-30-2010 | 09:07 PM
  #485
buellfooll's Avatar
Yeah. I cut quite deep. But there are four set screws so even if you cut into the black plastic ring REAL deep, which I did, the MOMO handle will still attach firmly and if you use a zip tie to attach the top of the boot and pull it good and tight it will lock onto the handle above the set screw bosses and the black ring just fills out the leather and gives some shape to the top of the boot. I actually goofed and started grinding on the metal part of the handle while the plastic ring was off and sitting on the bench before realizing it was the PLASTIC RING that had to be cut. But no harm no foul, I'm good to go as soon as my boots get here.
Old 01-30-2010 | 09:34 PM
  #486
yea i got ya, i was trying to file it haha ill cut that **** now thanks boss
sweet deal
Old 01-30-2010 | 11:51 PM
  #487
Rydis's Avatar
how is everyone securing the end of the boot to the ebrake handle and the shifter knob..you can't zip tie it through... And damn I got 1 in shorter with the twm and its slackier then my stock boot :/
Old 01-31-2010 | 10:16 AM
  #488
There's no need to really secure the boot at the bottom of the ebrake because the bezel itself holds it down really well.
Old 01-31-2010 | 12:58 PM
  #489
Rydis's Avatar
ok, so the handle holds the boot down on the ebrake..how about the shifter??
Old 01-31-2010 | 05:26 PM
  #490
RossGo's Avatar
Picture?
Old 01-31-2010 | 06:35 PM
  #491
Black08SSTC's Avatar
still waiting on my shift boot, ebrake boot and some other goody from them hehe
Old 02-01-2010 | 01:34 AM
  #492
RossGo's Avatar
Let me guess. You are the tester for the boot that will partially block the ebrake boot
if so, me too
Old 02-01-2010 | 07:15 AM
  #493
if so, me too
negative
Old 02-01-2010 | 12:00 PM
  #494
negative
I'm gunna guess....something to do with your armrest?
  #495
rico's Avatar
im gonna guess my stuff will be here today/tomorrow
Old 02-01-2010 | 12:08 PM
  #496
i hope mine is too!
Old 02-01-2010 | 12:09 PM
  #497
JUICED_SS's Avatar
heres mine
Looks great. Which Momo handle is that?
Old 02-01-2010 | 12:32 PM
  #498
Pit stop carbon
Old 02-01-2010 | 12:35 PM
  #499
JUICED_SS's Avatar
cool thanks
Old 02-01-2010 | 07:06 PM
  #500
CalgaryBalt's Avatar
Got mine in the mail, and when I looked at it I already knew it wasnt what I wanted, the shift boot was not the size i specified. ( 2" shorter then stock) as to ajust for my shortshifter, In fact its about an inch longer. and there were no instructions on there website as to how to remove old shifter and shift boot on the Lt.
Quick Reply: Shift and brake boots group buy
