Shift and brake boots group buy
Old 02-01-2010 | 07:39 PM
  #501
shroogis's Avatar
Finally got them!!! They look amazing!
These are crappy pictures (flash because of the dark, dirty interior and rubber winter mats FTL)
Old 02-01-2010 | 08:00 PM
  #502
camaromanss1992's Avatar
heres mine, crappy cell phone pics
Old 02-01-2010 | 08:01 PM
  #503
Originally Posted by OriGinaL Condo
Pit stop carbon
thanks boss for answering that dude's question
Old 02-01-2010 | 08:33 PM
  #504
skuruc's Avatar
Unhappy Boots
Had a Mix up with my boot order, but maciek was good on his word and is going to fix them for me. Off they go to Poland so It will probably be another three weeks.
Old 02-01-2010 | 09:45 PM
  #505
rico's Avatar
yep thell keep me as a costumer. good **** here guys
Old 02-01-2010 | 09:48 PM
  #506
BeermanSSSC's Avatar
is it just me or does that stitching look a bit unfinished?
Old 02-01-2010 | 10:00 PM
  #507
rico's Avatar
um actually i just noticed that too umm
Old 02-01-2010 | 10:03 PM
  #508
Rydis's Avatar
one of mine was the same way. Not a huge deal to me though..
  #509
I only say that because the opposite side looks like the stitching goes all the way up to the top and around to the back.
Old 02-01-2010 | 11:07 PM
  #510
rico's Avatar
yeh same here um um
Old 02-01-2010 | 11:19 PM
  #511
Just checked mine its the same. Don't think you'll see it once installed though. Its the seam, probably couldn't stitch through it.
Old 02-01-2010 | 11:22 PM
  #512
rico's Avatar
yah im not tripping
Old 02-02-2010 | 03:28 AM
  #513
RedlineGoods's Avatar
Originally Posted by CalgaryBalt
Got mine in the mail, and when I looked at it I already knew it wasnt what I wanted, the shift boot was not the size i specified. ( 2" shorter then stock) as to ajust for my shortshifter, In fact its about an inch longer. and there were no instructions on there website as to how to remove old shifter and shift boot on the Lt.
You have PM!
that is normal. Since the boot you have ordered is tight on top, the sewing machine won't go all the way in - it's header has a certain size and it just won't get anywhere.
This is NORMAL with the kind of boot that you have.
Please just try to install it so that the shorter stitched edge faces the FRONT of the car. This way you will not be able to see it while you're in the driver's or passengers seat and it'll look perfect.
Maciek
Last edited by RedlineGoods; 02-02-2010 at 03:28 AM. Reason: Automerged Doublepost
Old 02-02-2010 | 08:15 AM
  #514
rico's Avatar
yeh that what ill be doing
Old 02-02-2010 | 08:17 AM
  #515
Black08SSTC's Avatar
still waiting on mine, i hope they didnt get lost in the mail
Old 02-02-2010 | 08:30 AM
  #516
rico's Avatar
yeah same here
Old 02-02-2010 | 09:47 AM
  #517
pykie's Avatar
Got my boots, never got my e brake handle i was billed for.
shifter boot doesnt have anything so that it will stay up and around the aluminum tie down for my shifter like the stock one would.
quite disapointed i will not be able to instal these untill i got my e brake handle and got the boot re-stiched.
Old 02-02-2010 | 12:00 PM
  #518
CalgaryBalt's Avatar
Ya mine doesnt have anything to keep it up ether.
Old 02-02-2010 | 04:27 PM
  #519
Well, the stock one had a zip-tie in the collar. It's the same you need to use, really. Just flip the boot inside-out, slide the trim ring into it, grab it with a zip-tie and proceed to install the bottom.
Please make sure to slide the mounting bracket as far up into the boot as it will go, the boot has an extra 1" added to the bottom, we thought it would help the mounting but turns out to have been unnecessary, so just slide the bracket in deeper.
Maciek
Old 02-02-2010 | 05:11 PM
  #520
i didn't use a zip-tie and it works fine, a little lose but does not move. i put the stiching that does not go all the way up in the front and you can't even notice it. also i have a hurst short shifter and ordered stock length and i think it looks great, dont think there a real need to go shorter. only thing i had to do was trim where the clips go on the shift boot bottom bracket, but no big deal. I did use a zip-tie on the ebrake handle tho. note: you will have to shave some of the plastic on the ebrake to get the momo to fit perfectly, pass side and top, be sure to test fit the handle often so you dont over due it. The guides on redlines website were exactly as I did it.
look at my pics posted on last page.
Old 02-02-2010 | 05:19 PM
  #521
well no boots for me today
Old 02-03-2010 | 08:18 AM
  #522
pykie's Avatar
Maciek
Mine has no location to put the zip tie thru!
Old 02-03-2010 | 10:36 AM
  #523
NGASales's Avatar
Your momo handle went out Priority Mail it should be there anyday!
Old 02-03-2010 | 10:42 AM
  #524
rico's Avatar
yeh i need to order one of those
Old 02-03-2010 | 12:05 PM
  #525
You DO NOT PUT THE ZIP THE THROUGH!
Hope that helps
Maciek
Quick Reply: Shift and brake boots group buy
