Shift and brake boots group buy
Old 02-07-2010 | 04:19 PM
  #551
rico's Avatar
just added my ebrake boot FTW looks good damn i sure do need the handle tho soon. need to go add shifter boot now
Old 02-07-2010 | 08:05 PM
  #552
pickin my brother up's Avatar
Originally Posted by Sweetsandman
Yeah I broke the same piece..the shitty part is that you cant just order that plastic piec...you have to buy a whole new shifter and assembly...so I just ordered a Hurst short throw setup instead.
lol, looks like im gonna have electric tape under mine when i finally get it off then.
i find it funny how they said in instructions that any cracking is normal and is the metal underneath when the only thing under my shifter is a spring surrounded by foam...
when using a screw driver, the only leverage you can get is from the plastic piece under the shifter, which is why i broke it.
i have a feeling mine is glued because i know the owner before me had a short throw so at this point im just gonna bring it in and have then get the thing off themselves
Old 02-08-2010 | 11:00 AM
  #553
side0ut's Avatar
Ok.. I am still waiting for my boots to come in but I am getting scared from the horror stories about breaking shifter pieces and not getting momo handle installed correctly. Is there anyway that someone who has done the shifter boot and e-brake boot with momo handle can do a "how to" guide with pics for noobs like myself so we (I) don't F up my car?
Thanks,
Rich
Old 02-08-2010 | 11:01 AM
  #554
rico's Avatar
I did mines. i could help. ill be ordering handle soon too
Old 02-08-2010 | 12:04 PM
  #555
buellfooll's Avatar
Thanks,
Rich
It's not so much a "how to" as a "how NOT to". If it's the plastic cap with the shift pattern inscribed that is the problem the solution is not to MUSCLE the thing off. You have to be gentle. Go slow, VERY slow, and use as little force as possible. That cap, at least my 09, only snaps into place in the shift knob. Unless somebody has glued it in you should be able to finesse it off using the smallest flat screwdriver you have. Even grinding or filing it to a sharper edge might help get it further under the cap.
If it's the actual knob that's the problem a small puller will do the job very nicely. Uncle Sears has some cheap ones. With some imagination a steering wheel puller would work great. But again, you have to be a little creative. Understand you have to apply equal force to more than one point at the same time. Preferably two points opposite each other. Try using the impact method. Using whatever you have at your disposal to apply some force to the bottom of the knob EQUALLY with one hand and with the top screw screwed in 1/2 way hit the screw a sharp wack. This works better with two people but I did it by my self with no damage to anything. Try squirting some panther ****, nut buster, what ever you call it, into the screw hole and let it soak a minute till it goes down and then do it again. Many times a little heat helps with problems like this. Both adhesives and tight fitting metal parts. Understand that the splined parts are stuck together by friction and even, constant, pressure is the only thing that's going to separate them short of completely destroying them.
And that's MY 2 cents.
Old 02-08-2010 | 12:35 PM
  #556
trey ss's Avatar
Originally Posted by RedlineGoods
Guys a quick update. I understand that those who do not want the MOMO handle are going with this look:
If anybody who did not opt for the MOMO handle was expecting different than the picture above, please consider the ebrake handle to get this look:
There is no 3rd option, either the inner plastic ebrake is visible, or the MOMO.
Maciek
how much does the momo add to the finnal price and is there any other ebrake handle options???
Old 02-08-2010 | 02:01 PM
  #557
RedlineGoods's Avatar
Check this link for MOMO handle pricing: http://www.ngamotorsports.com/e-brak...f=REDLINEGOODS
Old 02-10-2010 | 10:56 AM
  #558
side0ut's Avatar
Well, I got the boots in Monday. They look great. Started to install them last night. E-Brake handle went on without any trouble. Just had to trim a little on the top and side of the original plastic piece. Did not want to cut my original handle so I made a cardboard piece to to simulate the bottom to give the boot some shape. Works great but there is nothing between the end of the handle and the bottom of the boot so my boot does not look perfect like in the pictures. Had some creases and such but good enough for me. Now on to the shifter. What a POS trying to get that dang knob off. The cap was easy. Tried taking the retaining screw out half way and hitting it with a hammer while pulling up with a pair of large channel lock pliers (with tape around the pinchers). Did not budge at all. Then tried hitting the crap out of the bottom of the pliers. Still no budgey... Finally called it quits around 8pm in frustration. Sprayed some WD40 into the top of the shift knob and called it a night. Will try again tonight after work. I hate that damm shifter knob.
Old 02-10-2010 | 11:06 AM
  #559
rico's Avatar
ha ill get it off in no time
Old 02-10-2010 | 11:10 AM
  #560
side0ut's Avatar
If I can't get the shifter knob off by this weekend, I may have to take you up on that offer. We will see.
Old 02-10-2010 | 11:13 AM
  #561
rico's Avatar
ha at first i was like wtf then used 2 flat head screw drivers on opposite sides and bam off it came
Old 02-10-2010 | 11:15 AM
  #562
side0ut's Avatar
Did you use them like the guide from Redline and pry it off? Was scared to break the plastic like other people have done. May give it a try tonight if that is was everyone else is doing and it works.
  #563
rico's Avatar
yes sir
Old 02-10-2010 | 11:24 AM
  #564
buellfooll's Avatar
Make an addition to your tool box. Once you have it, you'll find many uses for it. Trust me.
http://auto.sears.com/Item.htm?catal...0220820&appId=
Old 02-10-2010 | 11:45 AM
  #565
side0ut's Avatar
I had thought about getting something similar to that.
http://www.harborfreight.com/cpi/cta...temnumber=8832
Or even this.. it is in my price range also... Cheap!!!
http://www.sears.com/shc/s/p_10153_1...keyword=puller
Old 02-10-2010 | 11:48 AM
  #566
rico's Avatar
lol nice
Old 02-10-2010 | 05:03 PM
  #567
buellfooll's Avatar
A puller is one of those tools you never need because you can Rube Goldberg something and usually end up screwing up something. But if you DO have it in the box you'll find yourself using it pretty often and douing the job right the first time. Again! Trust me. I was a Snap On tool dealer for 2 years. The deal from Harbor Freight is great for the home mechanic.
Old 02-11-2010 | 09:55 PM
  #568
side0ut's Avatar
Finally got the knob off and finished installing everything. Thanks Buellfooll for the what not to do advise. Definitely helped. Thanks Rico for the help too. Also want to say thanks to Redline for an awesome product. Looks great. Could not get the ebrake boot exactly as nice and straight like yours but I think it still looks good. If I knew how to post a picture I would post it. Noobs.. Gotta love us!!
Old 02-11-2010 | 09:59 PM
  #569
rico's Avatar
where u post instead of doing post quick reply click go advance and then ull have the option to add pics u know what ill add them for u
Old 02-12-2010 | 11:59 AM
  #570
buellfooll's Avatar
Yes Sir. You're quite welcome. Now maybe you can write a "How To" for posting pictures. I know I'm not the most computer literate and definitely not the least literate but I've tried everything and can't figure out how to post a picture here. I've tried the "go advanced" but WHERE DO I FIND A URL FOR MY IMAGE???? I have pictures all over the place on the computer but nowhere can I find URL's for the individual pictures. I can back a 102" tractor trailer down a 114" alley a 1/4 mile but I can' t do this.
Old 02-12-2010 | 12:16 PM
  #571
rico's Avatar
TIME to hit up nga to get a handle
Old 02-12-2010 | 12:26 PM
  #572
side0ut's Avatar
Thanks Rico for posting the pics for me. I guess that is why you are a Senior Member and I am a Noobie Member..
  #573
rico's Avatar
bro anytime
Old 02-12-2010 | 12:43 PM
  #574
JUICED_SS's Avatar
that looks awesome!
Old 02-12-2010 | 03:18 PM
  #575
buellfooll's Avatar
Hot damn!! I think I've got it. Now if I could make them big enough to see??
Disregard the seat cover on the passenger side. That's only on there for my buddy Pedro. My Boston Terrier.
Looks much better when it's big enough to see.
Like I said. The seat cover is for Pedro. Believe it or not, he's actually happy here.
I don't know which I'm happier with. The great looking boots or learning how to post pictures.
Quick Reply: Shift and brake boots group buy
