Stance gr+ coilovers - lowest drop - best performance!!!
#384
Haz l33t wheelz.
Adam, you should talk to the guys at Stance. The 5k spring rate in the rear really just isn't enough. I watched someone drive my car over a speedbump, and the rear just flopped around, even with the shocks set full stiff.
I just put in 7k's from a BC racing setup, and the car not only feels more balanced, but it wants to rotate into turns more eagerly, and the whole car just feels tremendously better.
The shocks can't handle the more aggressive rate though, so it bounces and bounces lol.
I think if Stance went to a 6k rear, or a 7k with an upgraded shock, the car would be much happier.
Thanks,
-Will
Thanks,
-Will
#385
Thanks,
-Will
Thanks,
-Will
#389
Haz l33t wheelz.
Nah, i've heard the "upgraded" ones are even worse than stock as far as binding goes. but i don't have first hand experience. I just know when stu tried to lower the coilovers on your car, it had a lot of bind, but mine now is lower, and i have no issues
#397
Haz l33t wheelz.
#398
#399
Thanks,
-Will
Thanks,
-Will
#400
you got it sir...PM sent
huh??
Will,
if different rates or leangths of springs are needed we can make that happen for you. Contact me or STANCE for that as well as feel free to voice your opinions and suggestions so we can make things happen.
The other thing that we do and can do for you guys that want the ULTIMATE SPRINGS is to get some SWIFT springs thrown in there. Its a sweet upgrade!!!
More travel
30% lighter
less coils
spring can compress more
hold spring rate for longer compression time even at 2 inch compression
ride is smoother
more responsive
better to for real low setups
can go up 2K and retain same ride quality.
$289 SHIPPED for the UPGRADE for those who already have the GR+
not sure which ones you are talking about.... definitely not the SWIFT springs I bet.
you got it!!!
PM sent
LOL!?
Check out the Redline Time Attack - Circuit Battles PROMO Video!!!
Its pretty awesome!!!
Circuit Battles Sizzle on Vimeo
huh??
Thanks,
-Will
Thanks,
-Will
More travel
30% lighter
less coils
ride is smoother
more responsive
you got it!!!
PM sent
LOL!?
