Stance gr+ coilovers - lowest drop - best performance!!!
Old 07-12-2011, 03:51 PM
  #451
SupaCharged06's Avatar
PM sent
Old 07-12-2011, 06:27 PM
  #452
klloyd's Avatar
I wouldn't bother even trying to go through stance because its been almost 3 months since I ordered a custom set and they said 4-5 weeks max. Went through BC and got a custom 7k rear set and it's too bouncy for the shock to handle.
Old 07-12-2011, 06:33 PM
  #453
dandaman15's Avatar
Have you tried stiffening the rear shock?
Old 07-13-2011, 01:47 PM
  #454
thmotorsports's Avatar
Since its a progressive type rear spring, they have those outsorced to be built elsewhere. So they have no control as far as I know. That does suck.
Is the 7K same length as the Stance 7K rear?
+1
Old 07-13-2011, 02:08 PM
  #455
please shoot me a price to 60190
Old 07-13-2011, 02:36 PM
  #456
AWD > FWD
TommyP's Avatar
by too bouncy do you mean it's too hard? Or is it that the spring feels soft and doesn't control rebound well?
Old 07-13-2011, 03:12 PM
  #457
DCOBALTSS's Avatar
pm me on a price shipped to canada
thanks
Old 07-18-2011, 11:04 AM
  #458
BooSSted's Avatar
This is your car....
This is your car on Stance!
Old 07-18-2011, 11:41 AM
  #459
damastah's Avatar
doesnt this mess with your camber? and caster of your wheels?
your tires are going to wear out un evenly? am i correct?
Old 07-18-2011, 12:17 PM
  #460
dandaman15's Avatar
To a point. Only the front tires are affected by the drop. Its always recommended to get an alignment after you lower the car. Caster is not affected or adjustable with coilovers, just camber. What ever the caster is after you install them is what its going to be at, and it doesnt affect how the tires wear. Camber doesnt really affect how tires wear all that much either unless your over like 3* where the contact patch is only on the sidewall. Toe is what really eats up tires and what gets affected the most by the drop. However aftre installing my coilovers and dropping my car like 4inches the toe in the front was only off like .5* from spec. I just set it back to zero and went.
Old 07-18-2011, 01:55 PM
  #461
klloyd's Avatar
I have the rear set to full stiff but it feels like they can't handle the stiffer spring. I hit a medium bump and it keeps bouncing. Just not overall happy with how much I have spent on these compared to the ride quality, front is great but they REALLY need to improve the rear.
Old 07-18-2011, 03:16 PM
  #462
BooSSted's Avatar
Mine are set right in the middle in the rear and I don't get much bounce at all. My car is much lower than my SC was on sportlines and it rides a lot better now with the coilovers.
Old 07-20-2011, 05:12 PM
  #463
PMs sent.
Can someone get me the dimensions of the springs they want to run and I will look to see what I can get?
Let me know... I want to help. Hopefully the guys at STANCE can chime in.
The rear is a progressive spring. So you don't want to compress it too much. But should be able to handle it no problem no matter the drop.
-Adam
Old 07-20-2011, 05:18 PM
  #464
miltowncobalt's Avatar
How much!
Old 07-21-2011, 01:22 PM
  #465
klloyd's Avatar
The rear was full stiif so I dropped it down 2 clicks and it rides a little better. I am still waiting to hear from stance about my springs because the BC's I put on I had to take the lock rings off and there is still a finger gap between the tire and wheel well.
What kind of measurements do you need? I can take some from the stock rears that are sitting in my garage when I get back to MD on saturday.
Old 07-22-2011, 01:43 PM
  #466
Originally Posted by miltowncobalt
How much!
PMd ya!
Basically the dimensions of the ideal spring that you, or anyone else would want. Along with the ID,OD of top and bottom. I have one in stock, but Once its sitting in our warehouse its packaged up and in ready to ship condition. I really prefer not to open anything up and mess up the order of things.
-Adam
Old 07-22-2011, 02:18 PM
  #467
dandaman15's Avatar
How did you install the shocks when you put them on? Are you running the perches fully lowered in the rear? If your rear shock isnt set to the right length, that can cause problems too...
Old 07-22-2011, 02:23 PM
  #468
Omnigear's Avatar
sounds like the shock is not set right for the height, idk im not there . because i think will have bc springs n he dont have no problems with em.
Old 07-22-2011, 02:26 PM
  #469
08ssedan's Avatar
I'm about to see what stance is all about
Old 07-22-2011, 02:30 PM
  #470
ConroyCavScout's Avatar
i am also curious about the cost of these coilovers.
Old 07-22-2011, 03:04 PM
  #471
09PitchBlackSS's Avatar
PM me the price please
Old 07-23-2011, 08:11 PM
  #472
klloyd's Avatar
I was told by the tech at Stance to set the shocks at full low since I am running the car that low. Pretty sure i'm just gunna post them for sale and get a set of springs.
Old 07-23-2011, 08:15 PM
  #473
dandaman15's Avatar
How much? Pm me
Or you can trade for my Megans Ill set them up for you before I ship them so you wont have to worry.
Old 07-25-2011, 04:30 PM
  #474
PMs sent...LMK guys!
Old 07-28-2011, 09:53 AM
  #475
RG4
RG4's Avatar
pm a price plz .
Quick Reply: Stance gr+ coilovers - lowest drop - best performance!!!
