Bled brakes repeatedly, still soft w/ car on ***HELP***
Old 06-17-2014 | 10:28 AM
ssyellow's Avatar
Ahh, thats a different setup than I was thinking. There is a bleeder that hooks up top and pushes it through, yours was pulling it.
Old 06-17-2014 | 02:46 PM
Incognito11's Avatar
Yeah i've seen kits both ways but this was the one Harbor Freight carried and the price was right!
Old 06-17-2014 | 10:04 PM
ItalianJoe1's Avatar
Yeah I was using actual pressure on the reservoir bottle under the hood. 15 PSI was more than enough for a very strong flow and the system bled very quickly.
Old 06-17-2014 | 10:33 PM
chris88z24's Avatar
I did mine the old fashioned way with a piece of clear tubing and a breaker bar to hold the pedal down between the seat cushion. Worked like a charm
Old 06-17-2014 | 10:55 PM
That will probably not work if you have to do a major repair like an ABS module. So much line length and air gets trapped in the high points, you just can't force it all out that slowly. You need pressure or at least a helper to quickly cycle the system.
Old 06-17-2014 | 10:59 PM
chris88z24's Avatar
I only did calipers and hoses. Which are rusted again after a half of a winter.
How to Guide
57
10-15-2015 12:56 PM
Dustin24
10-08-2015 10:15 AM
calo247
09-08-2015 01:29 AM
soundjunky
09-03-2015 02:18 PM
