Bump stop cutting, Alignments, Camber kits for Lowering Springs
Old 04-15-2008 | 03:35 PM
  #51
Dunkinuts's Avatar
yeah my H&R race springs only made one wheel off a 1/6th of an inch. but i do you think i should cut my rear bump stops? i have about 3-4 inches (eye balled) of travel space when the car is on the ground.
Old 04-15-2008 | 04:03 PM
  #52
Halfcent's Avatar
I'm old school
Don't think! Just follow the instructions properly. Eibach went to the trouble of doing all the engineering for you.
Old 04-15-2008 | 04:06 PM
  #53
Dunkinuts's Avatar
well the H&R race springs didn't have anything shown. i can look again but i have taken it out on my test road and i haven't felt it bottom out. so i think i am fine.
Old 04-15-2008 | 04:42 PM
  #54
2fastSS's Avatar
just cut them their easy in the back anyway..... I fixed mine... believe me people you wanna cut ur bump stops that was my problem with a horrible clunkin noise every time i hit anything in the road and now its gone due to me cuttin the bump stops
Old 04-16-2008 | 01:15 PM
  #55
Halfcent's Avatar
I'm old school
That' would be H&R. The person I was qouting was using Eibach, which does have very specific instructions.
Old 04-16-2008 | 03:14 PM
  #56
IonNinja's Avatar
it seems to me that cutting your bump stops would make your rear shocks take a crap faster as its allowing for more suspension travel
so possibly a smoother ride yes but it seems at the chance of your shocks crapping out quicker than normal
still haven't cut mine yet with Sprint springs...
Old 04-16-2008 | 10:24 PM
  #57
Halfcent's Avatar
I'm old school
No, that's not a problem. The amount of travel wont effect the life of your shock. It's how well the seals hold up. The main killer of shocks and struts is literally time. As the seals gets older, they lose their effectiveness. Use really doesn't mess them up that much.
Old 04-18-2008 | 02:45 PM
  #58
Brraaapp's Avatar
I will be installing sportlines this weekend some time. I will cut the bump stops. Now do i or dont I need a camber kit. And will I need a allignment? And yes I read all the post. But keep getting different answers. Thanks greatly appreciated.
Old 04-18-2008 | 06:52 PM
  #59
Halfcent's Avatar
I'm old school
Do NOT need a camber kit.
DO need an alignment.
There is some dispute about whether or not the cam-style bolt camber kit will even fit this car. I say no, others say yes. But regardless, you shouldn't even need to start with.
When you get your alignment, everything might be just fine. But it most likely won't be. Which is why you need to go get one and find out.
Old 04-18-2008 | 07:18 PM
  #60
XgunsmokeX's Avatar
just dropped my cobalt myself, didn't need kit, but needed alignment job, toe was off alil
Old 04-18-2008 | 07:26 PM
  #61
Brraaapp's Avatar
thanks!!
Old 04-29-2008 | 11:26 PM
  #62
hoffs07cobaltLT's Avatar
Well. It all depends on how you take out your front struts. I took the top nuts off both strut towers first, then took nuts and bolts off of the knuckes. It all depends on how your process is to take out the front struts. And yes, cut your bump stops. I cut mine a little more than reccomended to allow break-in and travel over bumps. Very smooth ride.
Old 05-01-2008 | 12:19 AM
  #63
Halfcent's Avatar
I'm old school
What? The order in which you take off the hardware has nothing to do with anything. And cutting the bump stops more then instructed just allows the springs to compress more to potentially the point of coil bind. There is no advantage to it, only possible problems.
Old 05-03-2008 | 02:48 AM
  #64
dragonslayer27's Avatar
couldn't get a clear answer... i just got my progress springs a lil while back, do i need a camber kit? couldn't tell from the info sheet but is it necessary to cut ALL the bumpstops in half / fronts only / backs only?
Old 05-03-2008 | 04:46 PM
  #65
Halfcent's Avatar
I'm old school
I believe Progress is one of those companies that doesn't supply instructions. A call to their support phone line might be in order.
You don't need a camber kit.
Old 05-03-2008 | 05:21 PM
  #66
gfi thx. yea i didn't get any instruction with mine.
Old 06-05-2008 | 02:36 PM
  #67
typo's Avatar
whats a good estimate as far as stock struts lasting after prokit is installed?
Old 06-05-2008 | 02:47 PM
  #68
kwol18's Avatar
I put sportlines on my 2.2L a few weeks ago. Has anybody else noticed that the back end seems to sit lower then the front of the car? I'ts a very little difference if any, but to me it looks liek the back end is lower
Old 06-06-2008 | 07:15 PM
  #69
Halfcent's Avatar
I'm old school
I'm at 2 years and counting.
Old 06-18-2008 | 11:04 PM
  #70
dtabbs's Avatar
Superior Sport Chassis "SSC" Springs
OK guys and gals,
I finally have the official document for trimming of bump stops from SSC. I sent them an e-mail and this was their reply.
Originally Posted by sales@superiorsportchassis.com
We recommend the springs to be installed by professionals. However, we are pleased to attach a "Bump Stop Trim Guide" for your reference. Hope that helps.
SSC Bump Stop Trim Guide
Old 06-19-2008 | 02:36 PM
  #71
Halfcent's Avatar
I'm old school
Well I'll be damned. Nice find!
Old 07-11-2008 | 06:48 PM
  #72
ScottxKillyou's Avatar
Ok I just bought my car and I've been looking into getting sportlines. What happens if I don't cut the bump stops so that if i have any suspension problems I can throw the stock springs back on and take it in for warranty work
Old 07-12-2008 | 03:08 PM
  #73
Halfcent's Avatar
I'm old school
Your being paranoid. The addition of springs will not result in a problem. Follow your springs directions correctly and cut the stops.
Old 07-12-2008 | 03:17 PM
  #74
dman090's Avatar
the only way u can mess up is if u dont torque everything properly or you are a idiot and try to install them upside down or the front springs on the back or the back on the front
Old 07-20-2008 | 11:55 AM
  #75
BULLETSSMOKE's Avatar
Can I DIY my own alignment, I got a quote for $75 and I dont like the sound of that so much. I have an very LARGE arrangement and variety of tools.
