Camber Kit?
Camber Kit?
Ok, so i've found mixed opinions about this..
But i'm getting the Tenzo R lowering springs... will I need a camber kit?
Its supposed to drop 2 and 2.5 I believe
Thanks!
Thanks!
Yes a Camber kit is always a good idea. You tires will love you for it. You can buy a camber kit here.
http://cgi.ebay.com/ebaymotors/2005-...spagenameZWDVW
Dezod also has them.
http://dezod.com/pd_ingalls_engineer..._kitcobalt.cfm
deffinatly get a camber kit, i have the tenzos and they drop u alot more than that, google it youl find it for like $20 its just 2 bolts.... remember those 2 bolts you have to punch out because you cant screw them out? its those only these ones turn and adjust camber.
Camber kit for the car with that type of drop will be good.
Originally Posted by Vette Jr.
call me a noob, but how exactly does a camber ajustment kit work, and how do you know what degree your wheels should be at?
Camber bolts are a cheap answer for something to annoy you. I tried them for a cheap way to more camber in the front of my Z24(with pro kit springs) and it did give me more camber BUT it also gave me more toe in and well at the solo1(time trial) I went to I had to retighten them allmost halfway through the day, just a pain in the ass more then anything.
have your car aligned and chances are the toe will be out a bit but the camber will probably be within or close to the specs.
09-28-2015 01:51 PM
