Drilled and Slotted Front Brakes.........
Old 08-17-2008 | 11:43 PM
Feardavid0586's Avatar
My recently purchased 06 SS/SC has drilled and slotted front brakes. my question is did this come factory? or is it aftermarket?
you can barely see them here but you get the idea....
Old 08-17-2008 | 11:44 PM
joeworkstoohard's Avatar
that depends, there ARE GMPP rotors that are slotted and drilled, but my guess is that they're aftermarket.
SS rotors are known for warping and wearing easy, so a lot of us just swapped in a cooler running set.
Old 08-17-2008 | 11:51 PM
thanks i had been wondering for a while but i work soo much i never get to go on. i'm still trying to figure out if my SS has stage 2 pulleys or not. What does the stock pulleys boost out at.
Old 08-17-2008 | 11:55 PM
got me, it's gonna vary depending on a lot.
easist way to tell is to look at the pully, the S2 is held on with four small blue weird bolts. the stock is just pressed on.
Old 08-19-2008 | 08:55 AM
celicacobalt's Avatar
those are not stock. my drilled and slotted are from uneek.
DarrenGC
12-24-2021 02:55 PM
01-12-2016 01:01 AM
SSLOW06
10-01-2015 08:21 PM
n20saturn
09-30-2015 01:26 AM
09-27-2015 09:53 PM
Quick Reply: Drilled and Slotted Front Brakes.........
