Engine subframe/cradle swap
Old 08-20-2018 | 01:30 PM
intel's Avatar
Hi everyone,
I am in the process of swapping out my engine cradle/subframe. My current car has the one bolt/tab for securing the swaybar. I got a great price on an Cobalt SS/TC (LNF) engine cradle that has two bolts to secure the swaybar. I also ended up using the LNF swaybar as well. Figured it would be a neat little project to attempt.
I have 2.2L cobalt (F23) and everything swapped in fine. The only thing that caught me off guard was the lower radiator mounts. The LNF cradle did not come with one and I thought I could reuse the ones from my car. Apparently that's not the case as they do not line up.
Taking a look online it I came across the following part numbers. For those that did this swap do I need the LNF lower radiator mounts and support?
Part numbers 10368833, 22702290, 22702291
Don't ever recall anyone ever mentioning those in previous threads but it may have been something I glossed over.
Thanks
Old 08-20-2018 | 02:13 PM
jdbaugh1's Avatar
Did you swap the subframe just to utilize the 2-bolt sway bar bracket or for multiple reasons?
Old 08-20-2018 | 03:04 PM
intel's Avatar
Well my car has over 150,000 miles on it with original steering rack, inner tie rods, and outer tie rods. With having another subframe it was much easier to just install all those parts and torquing everything to spec prior to swapping it. I really wanted to just give it a go and attempt swapping it because I have never done it before. It is definitely a weekend project and helps if you have a buddy assisting you. Having the 2 bolt was a bonus and I wanted to utilize a SS/TC swaybar as I have already swapped the rear beam with one from a SS/TC as well.
Old 08-21-2018 | 07:15 AM
jdbaugh1's Avatar
Just curious. I don't know about the different mounts. I thought they were the same on all Cobalts. I personally have swapped to the two bolt clamp by drilling an extra hole so wasn't something I ran into.
Old 08-25-2018 | 02:17 AM
intel's Avatar
Wanted to provide an update. The mounts I ordered arrived in the mail and they are the same exact ones that I had on my old subframe. Taking a look again at the subframe I swapped I determined that the tabs for the lower radiator mounts are bent. I should have scrutinized them further. Oh well lesson learned, might have to take it to a shop to see if they can straighten out the tabs.
Old 08-25-2018 | 09:43 AM
If you take it to a fab shop they might be able to weld the rad support in the correct location
Old 08-28-2018 | 08:24 PM
intel's Avatar
Yea ended up taking it to an autobody shop, they were able to straighten out the tabs. The second option if they couldn't was to weld them in. Glad they got it done, much easier when you have a lift. Paid about $70 bucks. Radiator mounts are now good.
Old 08-29-2018 | 01:07 PM
Bass_Waves's Avatar
Only diff is the swag bar. 1 bolt to 2 bolt clamp down. If you have an 04. The front trans mount is diff position. Also the rad supports are a bit different. Aside that. That’s it really.
cw383
11-07-2016 09:03 PM
BLACK09LS
11-18-2012 09:29 AM
Ltguy
08-07-2012 09:15 PM
jkon
04-15-2012 07:36 PM
JohnnySasakiMGS
Forced Induction
11-03-2007 03:42 PM
Quick Reply: Engine subframe/cradle swap
