im pissed.......f*&kin control arms
Old 04-10-2010 | 11:05 PM
Tank07's Avatar
Originally Posted by 09blackonblack
beat me to it john. and yes it is a MAJOR PITA to spread the knuckles but its well worth it! i have them on my car. oh and thanks again john
not entirely true... my 09 has ss/sc LCAs
yea since th SS/SC control arms are smaller and ur knuckle is bigger so ya they can fit
let me put it this way
for 07 and older YOU CAN NOT USE SS/TC lower control arms since the ball joint is too big.....use SS/SC lower control arms
it is true u can spread the knukle and what not but why do all that? the only difference between the SS/SC LCAs and SS/TC LCAs are the ball joint....otherwise they are identical so i would just take what ive learned and use it
Originally Posted by qwikredline
you said it. Proper attention to detail as written in these posts you would be fine. Open up the knuckle .030 and in you go...you can probably re insert the shaft into the plunge joint I imagine thats what has slipped out....meh
it did....i wound up wrecking it though
Old 04-12-2010 | 10:47 PM
scagnetti76's Avatar
thanks to all for the info in this thread.
Old 04-13-2010 | 02:53 AM
Area47's Avatar
Rent me! per hour
i have a set of ss/sc knuckles. sitting. collecting dust.
Old 05-19-2010 | 06:42 PM
DiMaggio's Avatar
Ok I got an 06 ls ant I got the fe5 ss/sc control arms, the passenger side fit right on but the driver side won't fit, the ball joint is bigger but it is the ss/sc control arm 8be checked the part number, anyone else have this problem?
Old 06-02-2010 | 11:51 PM
FraGmE's Avatar
raw deal tank. I bought some replacement LCA's awhile ago so I hope I got the right year. I don't remember at the moment.
Old 06-03-2010 | 09:34 PM
qwikredline's Avatar
it beats me how folks can wreck their parts fitting them. time to consider going to a trained technician this is not rocket science I fit these things once or twice a week...and the range is 19.6 mm to 20.5 mm on the bj stud, that I have found...
ColonelMustard
North Pacific
09-29-2015 04:02 PM
yellow dragon
09-28-2015 10:49 PM
metroplex
09-27-2015 08:48 AM
09-26-2015 07:44 PM
Coballin13
09-25-2015 09:43 AM
