im pissed.......f*&kin control arms
let me put it this way
for 07 and older YOU CAN NOT USE SS/TC lower control arms since the ball joint is too big.....use SS/SC lower control arms
it is true u can spread the knukle and what not but why do all that? the only difference between the SS/SC LCAs and SS/TC LCAs are the ball joint....otherwise they are identical so i would just take what ive learned and use it
it did....i wound up wrecking it though
Ok I got an 06 ls ant I got the fe5 ss/sc control arms, the passenger side fit right on but the driver side won't fit, the ball joint is bigger but it is the ss/sc control arm 8be checked the part number, anyone else have this problem?
it beats me how folks can wreck their parts fitting them. time to consider going to a trained technician this is not rocket science I fit these things once or twice a week...and the range is 19.6 mm to 20.5 mm on the bj stud, that I have found...
