New Shocks and Springs... Still making BANGING noises...
Old 08-20-2016 | 08:05 PM
Jrg77's Avatar
2010 Cobalt SS
Had the rear axle replaced last year. It was bent, and hard to control the car in wet/snowy conditions.
Started having Banging Noises.
I figured it was the shocks. I saved up and bought the Shock/Spring package from CED.
I put the rear shocks and springs on, and I STILL have the BANGING noises.
Is there a bushing to replace back there? It sounds as if something is hitting like I have no shocks at all. The only other thing I can think of are the insulators that sit on the spring mounts.
This video,
, said they are no big deal, and my car only had the top insulators. The top insulators were pretty beat up, and not holding anything, so I left them out. Can they make that big of a difference?
The bottom insulators look to cost about $10 apiece. The top looks like it only comes with a new mount. Am I looking at this correctly?
Thanks for reading and replying.
Old 08-21-2016 | 07:25 AM
Tdubbs's Avatar
It's possible it could be your noise. Crate Engine Depo has replacement rubbers for the top spring mounts that replace the cheap foam,
Rear Upper Spring Insulator CED2797
$10 each like the lower, so $40 will get you new rubber on both top and bottom.
Edit: The lower seats are actually only $4 each, so $30 instead of $40.
Old 08-21-2016 | 08:09 AM
Supercharged06SS's Avatar
Banging when you hit a bump in the rear? I have a similar issue
Old 08-21-2016 | 01:34 PM
cluelessk's Avatar
Oh Geeze.
You need the isolators. Of course you hear a noise, it's metal on metal.
Old 08-27-2016 | 08:31 AM
Jrg77's Avatar
Actually, without the insulators, they sit on plastic mounts.
The insulator for the top only comes with a new mount. For the bottom CED appears to get a rubber disc made.
I got them both, and installed them.
It's better, but still crashes noisily over bumps.
What else is there back there?
Old 08-27-2016 | 09:50 AM
You can check the bushings and see if they're shot or not. Also could be exhaust hitting somewhere?
Old 08-27-2016 | 10:13 AM
colodude18's Avatar
I'll just share a few things I fixed that were causing banging noises:
1. Twising beam bushings.One of mine had some serious play, see the first link (with video) below. I replaced mine with Powells.
2. Your exhaust may be hitting the top of the twising beam. I have the Hahn catback that is notorious for that.
3. You rear springs binding could make a similar noise. I have wrapped mine (YYZ3's) in wiring sleeves and it fixed it. See the second link.
https://www.cobaltss.net/forums/susp...shings-301971/
https://www.cobaltss.net/forums/susp...ml#post7562843
63 Nova SS (08-28-2016)
Old 08-29-2016 | 09:44 AM
yellowsupercharged06's Avatar
what kind of noise is it ? can you get a video ?
What springs do you have on there ? Is it over tiny bumps / cracks in the road ?
could be coil slap. CED has a solution for that as well.
CobaltNationSS
03-13-2016 07:52 PM
Jockjsaifja
03-05-2016 12:39 PM
doug41176
02-25-2016 02:09 AM
Ontario 905 Slobalt
02-12-2016 01:25 PM
zinner
10-14-2004 08:08 PM
Quick Reply: New Shocks and Springs... Still making BANGING noises...
