Official Koni Club
Old 04-15-2008, 02:42 PM
  #51
CobaltSS 16's Avatar
How hard is it to adjust them?? Do you have to take the wheels off in the back?
Old 04-15-2008, 02:44 PM
  #52
gRuNg3b0y's Avatar
Originally Posted by Dunkinuts
i had them at full stiff when i was test driving them after i put them on so see if they move around etc. and the ride is nasty (on back country roads) but on a smooth track it would be perfect. but right now i have the front and a half turn from full soft and the rears are the way they came out of the box.
hmm I guess I'll keep mine half stiff front and the same on rears.. maybe it'll handles much better when I get that TTR rear swaybar
Old 04-15-2008, 02:46 PM
  #53
RuSSo-29's Avatar
I'm in the club!! I'll post em up when I get home. I got mine with the THMotorsports deal! Koni Yellow's + Sportlines!
Old 04-15-2008, 03:03 PM
  #54
Dunkinuts's Avatar
well if you have the stock tires, the way i have it set up now, the tires can't keep up with my suspension. not enough grip. but i will say that i handles like a cooper s right now. ( was test driving them with the optional sport suspension) and that is saying something. Though i may give them another half turn at the front but i am trying to feel how stiff the rear is and have them balance each other but i really need to just pull off the rear and adjust them.
when you get pics your number 7
Old 04-15-2008, 04:53 PM
  #55
mtp082.2's Avatar
I just bought some konis and sportlines, sounds like it is worth the trouble to install the fronts on my own? I will get some pictures up, when I have them on the car.
Old 04-15-2008, 04:57 PM
  #56
Dunkinuts's Avatar
def. worth putting them on, its not as hard are it seems. you just measure and cut. then clean up the cuts. the only draw back is you can't go back to stock unless you buy whole new front struts.
Old 04-15-2008, 05:19 PM
  #57
mtp082.2's Avatar
Ok cool thanks, can wait to get them on and see what they are all about
Old 04-15-2008, 05:24 PM
  #58
Brandon97Z's Avatar
Fronts are done via a knob on the strut tower....the rears yeah you have to take the tires off to get to the two bolts that hold the strut in. Its an easy job though i can do both in 5 minutes with air tools
Old 04-21-2008, 10:51 AM
  #59
Dunkinuts's Avatar
bump, just got done with a 1200+ mile weekend (ohio meet) and the konis were awesome!!! now some 85-90mph bumps aren't fun but it rode perfectly
Old 04-30-2008, 10:55 PM
  #60
Dunkinuts's Avatar
we need to keep the konis rock'n!!!! i have had mine on the same settings for some time now and now that they are "broken" in they are perfect!!!
Old 04-30-2008, 10:57 PM
  #61
cobaltBlackss's Avatar
How do you adjust stiffness on the rear strut with these?
Old 04-30-2008, 11:06 PM
  #62
Dunkinuts's Avatar
check the first page
Old 05-01-2008, 03:53 AM
  #63
RA080424's Avatar
I think I'm gonna take off the rear wheels this weekend and tighten up the rears. I've had the rear struts on soft ever since I've owned them.
Old 05-05-2008, 03:53 PM
  #64
gRuNg3b0y's Avatar
Off topic question. Does anyone using sportline springs hears clunking/clicking like noise on their car?? I usually hear mine when backing up and cruising esp when hitting bumps.
Old 05-07-2008, 02:52 AM
  #65
RA080424's Avatar
Yes I do too. Only happens when I turn the wheels sharply at low speeds. I looked it up, one of the parts of the steering column or suspension wasn't lubricated correctly from the factory. It SHOULD be a harmless nuisance.
Anyways, I tightened up the rear struts today on the firmest setting and put the fronts all the way on firm as well.
**** YES!
Total **** guys! Took a pretty sharp turn going about 30 miles an hour today, smooth as butter and no loss of grip from the tires. I probably could have hit it going way faster!
Old 05-07-2008, 03:20 AM
  #66
gRuNg3b0y's Avatar
**** YES!
alright thank you!! Well just realized that the logo on my rear springs are upside down but I'll get it fixed up soon as I get the time.
Old 05-07-2008, 09:25 AM
  #67
Dunkinuts's Avatar
yeah that I have that on the right front, it almost sounds like that springs aren't sitting just right. But i agree on full firm, the konis are a beast!!!
Old 05-09-2008, 01:11 PM
  #68
sherm420's Avatar
yeah i just got mine on weds!! ill post some pics up when i get home so i can join the club...the ride is sooo much better KONI FTW!!!
Old 05-09-2008, 10:44 PM
  #69
sherm420's Avatar
install
so im in
Old 05-09-2008, 11:03 PM
  #70
Switt23's Avatar
neat...
Old 05-10-2008, 12:18 AM
  #71
Dunkinuts's Avatar
updated
nice set up you got there sherm420, what brakes are those?
Old 05-10-2008, 10:58 AM
  #72
sherm420's Avatar
umm if im not mistakin powerslot but i have a pretty shitty memory due to mary jane
Old 05-22-2008, 05:13 PM
  #73
Newest member right here
Old 05-22-2008, 10:57 PM
  #74
Dunkinuts's Avatar
got photos man? the one in your images doesn't show the koni if that was one of the install.
Old 05-22-2008, 11:00 PM
  #75
dman090's Avatar
so do the konis actually the car?
Quick Reply: Official Koni Club
