Powell rear sway bar
Old 09-26-2014 | 07:19 PM
moonmtx02's Avatar
I have a Powell rear sway bar I'm planning on installing and was wondering if anyone knew the correct "bolts" needed as I do not have them... I searched around with no luck on how to install the sway bar either but I'm sure I can figure it out as I've done others.. I have the "hardcore series" sway bar
Thanks for the help in advance
Old 09-26-2014 | 07:36 PM
Try to message powell he should know
Old 09-27-2014 | 04:29 AM
andrewcarr1993's Avatar
Do you have the brackets? If so go to a parts store and buy, grade 8 or 10 bolts, if not then get new brackets and bolts from Powell.
Old 09-29-2014 | 06:36 PM
SPOOLING's Avatar
I need these as well.
I contacted Powell prices are:
Nut plates are $25 a pair
Bolts are $15 per 4 bolts
Plus shipping.....
Old 09-29-2014 | 10:11 PM
kzak104's Avatar
$15 per four bolts?
dat profit margin
Old 10-01-2014 | 02:25 PM
Viperoni's Avatar
Originally Posted by kzak104
$15 per four bolts?
dat profit margin
Knowing powell he's probably not using cheap "Grade 8" bolts from HD.
The right hardware isn't cheap... but you don't have to worry about it snapping either.
Old 10-01-2014 | 11:13 PM
SPOOLING's Avatar
Yeah exactly. I'll probably bite the bullet soon and order the hardware from Powell. I'm having a hard time trying to find it anywhere else.
Old 10-02-2014 | 10:03 PM
kzak104's Avatar
the ones i got with my car arent stainless and rusted in no time. when your buying bolts in big bulk like im sure he does you can usually get them for a dollar or two.
Old 10-02-2014 | 10:50 PM
Powell Race Parts's Avatar
these bolts are cad 10.9 8.8 wont do it. so the advice is well given on here.
Old 10-02-2014 | 10:54 PM
best advice I can give you if you dont want to get them from us is go to Fastenal and buy automotive 10.9 cad plated fasteners. they are not cheap. 60 mm long
get some large washers if you dont want to spread the load with nut plates. and mechanical lock nuts, you cant get the same result with a nyloc.
Old 10-02-2014 | 11:09 PM
stainless is a grade 5 strength and will snap if you torque to 55 ft lbs. so not a good move.
10.9 and proper torque with rust prevention ( all our stuff is shipped with moly anti seize on the hardware.) and you can buy the hardware cad plated for about 1.25 each plus shipping. so save ten dollars and buy inferior stuff, or go do the hardslogging and visit fastenal and make your own nut plates. OP if you are stuck let me know.
and for the record we replace hardware free if the original owner has a problem with corrosion. We do follow a continuous improvement process and the stuff we make now is a lot different even the nut plates have changed,and you can see that as the copied stuff does not improve or is just wrong.
its an accepted fact in many places, for example, that stainless hardware is equivalent to grade 8 ; that is just not so. We strain gauge and test stuff, and the hardware tests are easy. We did try stainless at one point because, as Kzak104 points out, corrosion is a big issue. The stainless stuff doesnt corrode , it just breaks. The nuts do corrode as well, the nut plates are not stainless. Thats why we went to cad plated 10.9 hardware, powdercoated nut plates and antiseize applied to fasteners.
Old 10-02-2014 | 11:11 PM
thanks eddie, this is the first I heard of this deal. Generally FB is the place for instant response or texting works.
Old 10-03-2014 | 07:50 AM
mongorat427's Avatar
My next store neighbor works for Fastenal. Ill check on them. Whats the thread size used.
Old 10-03-2014 | 07:54 AM
Stainless bolts are nice for bolting low torque parts up but if you even slightly over torque them they will stretch and fail down the road
05-28-2022 04:47 AM
SSLOW06
10-01-2015 08:21 PM
DANRICKARD
10-01-2015 01:08 AM
nathan112i
09-30-2015 08:12 PM
09-26-2015 07:44 PM
Quick Reply: Powell rear sway bar
