Powell's take on replacing bad control arm bushings.
Old 08-25-2013 | 12:15 AM
  #51
colodude18's Avatar
well I am happy to say that YYZ springs are made in USA!! The best. Inspired by Wangspeed. Our sway bars are made in Canaduh from German sourced Chrome Moly purchased from a USA distributor. Inspired by Time Attack but a pure Powell idea.
Same for rotated mounts made in Canada. Inserts from....USA/Mexico/India...what month is it? China prolly next.
Our trap door pans made in Canada from OEM pans made in Israel, China or Chechoslovakia. I never know.
Our tow hooks are made in Canada of canadian steel with fasteners out of Indianapolis.
Our PCV upgrade setup was developed by me with engineering input from the USA, assembled in Canada. I suspect our Russell AN fittings are made in China. Our Mann Hummell seperators are.
OUr harness bars and UCR made in Canada, same thing applies for the Chrome Moly as above the DOM tube s canadian made.
etc. I am with Colordude but agree with USMC, and will say its very hard to match some prices of off shore stuff. 60% of the Camaro is made from parts sourced in China, the worlds largest car market.
and to all of you that buy our parts instead of the copies from other vendors here
thank you.
Thanks John! I am not so naive to think EVERYTHING can be American made, but it matters to me that companies care and try. It's clear to me that Powell Race Shop is such a company
Customer for life!
Old 08-25-2013 | 12:22 AM
  #52
colodude18's Avatar
Yeah no kidding! I hand torqued mine and it felt pretty damn tight but then I got the torque wrench and had to give them another ~3/4 turn to get them to 85 ft lbs!
Update: After installing my rear twisting beam bushings today (with thanks to ECaulk for all the help!) I decided to check the XXX bar bolts. The passenger side needed another 3/4 turn and the driver's side a full turn!! We were starting to question the torque wrench until it finally said "click"
Check those bolts people! And then check them again after a few weeks!
Old 08-25-2013 | 01:52 AM
  #53
Dave082.4's Avatar
John installed some goodies for me the other day, and last on the list was his Hardcore bar. He snugged up the fasteners, and then pulled out his "new" clicker torque wrench and started torquing them down. He kept torquing and torquing and started to question whether the torque wrench was buggered since it didn't click. I had adjusted and locked the setting and began to think I screwed up. Then it finally clicked. Even John was surprised at how many turns it took before it clicked.
Old 08-25-2013 | 02:01 AM
  #54
Dave082.4's Avatar
thank you.
And I think I speak for most when I say it is a pleasure to work with the Real Deal!
Old 08-25-2013 | 09:06 AM
  #55
Youre welcome, it was interested to see how the rear beam is put together, easier change that I expected. And only one trip to the parts store
We ended up trying it on a wheel since it was a higher torque setting to make sure it would actually click
Old 08-25-2013 | 07:58 PM
  #56
Powell Race Parts's Avatar
^^^^click.
lol/ truth. good work on that twb.
Old 08-28-2013 | 08:16 PM
  #57
noorj's Avatar
Anyone else have suggestions on how to get siezed subframe bolts out? I was able to loosen them, and can feel that they backed out but the sleeve is spinning with the bolt, CAB 100% torn lol
soaking in PB blaster now to try again, then might try holding the sleeve with a pair of vice grips
Old 08-28-2013 | 08:27 PM
  #58
Gelladuga69's Avatar
I had my dad do this.
Old 08-28-2013 | 09:06 PM
  #59
noorj's Avatar
Well after trying to do that the metal support that keeps the castle nut from spinning snapped and now the castle nut just rotates. ****!!!!
excuse my language, I'm just lost as to what to do....
I can try holding the castle nut with a wrench/pliers but I still can't get the bolt to back out from the subframe.
Close to just taking it somewhere, and I literally have never done that before.
Old 08-28-2013 | 09:45 PM
  #60
Noor you are a good guy but this frustrates the crap out of me. Here is my post, the purpose of this thread:
Remove the cradle; the engine can hang on the upper engine mounts. remove the plastic splash shields, the ball joint cross pins to the knuckle and the sway bar end links; the lower front engine mount cross bolt and the three rear cradle mount bolts, the steering rack bolts ( lock the steering wheel in place) and then undo all the cradle bolts, dropping the cradle.
you will be left with the control arms in place and you can now deal with removing the seized cab. Heat and a hammer on the end of the cradle bolt and it will now ( with a struggle) come out, and happily the captive nut will be undamaged.
A
now you still have to do that, as the bolt will come down and the captive nut will actually let the bolt unwind. if it doesnt putting a screwdrive in the top will stop it.
so. please read. remove cradle.
Old 08-28-2013 | 10:14 PM
  #61
Cherry GT's Avatar
So Mr. Powell... I have an 07 G5 GT with alloy FE3 control arms.....
which trailing bushing do I need from you, spherical, delrin or what
to fit the stock control arms ?
Thanks for your time...
Old 08-28-2013 | 10:18 PM
  #62
rear control arm bushings all weather spherical will be enough, that is the TRAILING CAB. 199.00
The leading (front) CAB is not Delrin, its a composite material I dont divulge that resists salt.
you dont need leading CABS unless your arms are shot.
Old 08-28-2013 | 10:25 PM
  #63
Cherry GT's Avatar
Cool..... so I e-mail gloria tell her I want the all weather spherical TCAB's ?
Is there difference in FE3 and FE5 TCAB's ?
Thanks again.
Old 08-28-2013 | 10:40 PM
  #64
alloy arms are alloy arms. fe 3 and fe 5 have different durometer rubber trailing cabs. My spherical make rubber durometer a thing of the past. lol
Old 08-28-2013 | 10:49 PM
  #65
Cherry GT's Avatar
Thanks...
I'll mail her tomorrow.
Old 08-28-2013 | 10:50 PM
  #66
chris88z24's Avatar
Why do you have to drop the engine cradle? Can't you just take the control arm out of the car and bring it to a machine shop to press the old one out and new one in??
Old 08-28-2013 | 10:57 PM
  #67
wow. the answer to the issue is in the first post. I must not be able to write it clearly enough. The center of the cab insert is steel it rusts to the bolt, and when you unscrew the bolt the seized sleeve wont let the bolt drop and it wrecks the captive nut.
post 1. please read.
Up until now, I had figured that the primary issue is corrosion seizing the cradle/control arm bolt captive nut. Its probably not. Its the control arm bushing center sleeve seizing on the bolt and stopping the bolt from dropping as you unwind it, and therefore tearing the captive nut out of the body.
that means, Chris you cant get the control arm out as the bolt wont drop. Noor is at the end of his rope, and didnt read what I had posted, and me, I figured by posting this thread I would help people NOT wreck the captive nut.
i was wrong i suppose.
Old 08-28-2013 | 11:01 PM
  #68
noorj's Avatar
John- Sorry I didn't elaborate more:
When I did my clutch 2 weeks ago and had the subframe dropped I did try to get the bolt out. Hammering on it for 10 minutes literally did nothing, I feel like a true press would have been needed. I gave up after this and reinstalled everything with the bad control arm bushging. Thought it would be better to install your spherical ones anyways instead of the BS replacements I bought at autozone. So your saying I should drop the subframe again and try with a hammer?
Old 08-28-2013 | 11:08 PM
  #69
yes. if you dont drop the subframe you are screwed. you can cut the bolt head off, the arm wont come out. you can torch the control arm but you risk burning your car to the ground. you can sawzall the insert and the bolt and risk screwing the arm and the cradle.
drop it.
then heat the center bushing insert. it will burn away quickly cherry red is best. Prepare in advance by placing a large pipe or socket over the bolt head underneath against the cradle. and then hammer. A press would be ok but awkward, and not as effective as impact from a BFH. PS Noor text or email me next time happy to help.
Old 08-28-2013 | 11:11 PM
  #70
chris88z24's Avatar
Cut the bolt. lol
Old 08-28-2013 | 11:23 PM
  #71
Cherry GT's Avatar
yes. cherry red is best.
TOTALLY AGREE !
Old 08-28-2013 | 11:26 PM
  #72
Cut the bolt. lol
Did you not read powells post? The arm won't come out if you cut the bolt...
Old 08-28-2013 | 11:28 PM
  #73
PS IN my how to for installing cabs that I send folks who purchase cabs, I suggest using a propane torch to heat the arm up in the cab eye to grow the hole, prior to installing the new spherical cab. We make the new CAB insert a hard fit, and using heat and an hydraulic press or the GM Kent moore tool will work well. Not using heat will make it much more difficult.
Old 08-29-2013 | 01:41 AM
  #74
cabs are SO hard to get in!!
any chance you could link me to that how to that you send people?
Old 08-29-2013 | 09:39 AM
  #75
email.
