Rear suspension rattle? Check your bushings!
Old 11-26-2013 | 03:44 PM
what are the added benifits of using powells compared to just replacing them with stock bushings from CED ?
Powell $395 + shipping
or
CED $160+shipping
Thats a huge price differential. Just curious cuz mine need replacing
Powells provide better rotation, also they're a solid plastic not going to even guess what he uses. The stockers are much softer, also is that the price for one or 2 from CED? (Too lazy to look it up lol)
Old 11-26-2013 | 03:47 PM
yellowsupercharged06's Avatar
better rotation ? threw cornering ?
CED has them for $80/each.
Old 11-26-2013 | 03:49 PM
Keep the rear wheels planted through turns iirc
Old 11-26-2013 | 04:43 PM
07blackg5's Avatar
Slobodan Milošević
gmparts direct has them for 155 shipped
25782808 INSULATOR
Old 11-26-2013 | 05:53 PM
colodude18's Avatar
Apart from Powell's being an upgrade, they aren't subject to the wear you and I both had on the stock ones. So keep replacing the stock ones or get a set that will last forever... ;-)
Old 11-26-2013 | 06:06 PM
colodude18's Avatar
Originally Posted by Econobox
Thanks for the info, I might have to do that. It sounds like the underbody rails suggested by disposable hero are a reasonable solution to my "problem" though. If they don't weight too much or are crazy expensive. I'm a pretty firm believer in subframe rails too so perhaps that will work out for me.
The Under Carriage Rails is something that's on my list as well. Here's the link and pricing:
https://www.cobaltss.net/forums/7008041-post98.html
Old 11-26-2013 | 06:26 PM
Powell Race Parts's Avatar
the twisting beam upgrade uses a machined composite outer shell ( not delrin) with a spherical joint, alloy sleeves and a larger cross pivot bolt and stainless nyloc nut. stock appearing
the whole point of re working the suspension for performance apart from durability, is to eliminate friction wherever possible. The use of rubber to isolate harshness and noise becomes a secondary, not a primary consideration.
At the rear the twisting beam flexes in the rubber bushings. As it does so, the pivot point distorts and that causes (due to the way the twisting beam works) a change in the roll center on an ongoing basis.
As a FWD car drives off the front wheels and the rear just follows along as best it can, frequently compromises are made for handling on the track. Thats where you see Hondas and Cobalts with 900 lbs rate rear springs. The car skips at the rear like a mouse eating a 220 v cable; good drivers just keeps the gas pedal buried and hopes for the best.
By using quality rising rate springs, spherical pivots and an add on Powell hardcore or xXx rear bar, the car becomes much easier to drive, more responsive and therefore faster at the limit. At the limit the car becomes difficult as all cars become but easier to place predictably on the race track, coz the rear doesnt skip.
On the street the car doesnt rattle anymore from junk bushings. The same sort of thing applies to the front control arm bushings. While the geometry is such that the roll center is unaffected, stock cabs allow a lot of movement in and out and forward and back. That leads to excessive torque steer, and on the track positive camber, which means horrible inside rib tire wear as the whole front wheel assembly tucks under as the cab compresses inward. It also causes the car to slow down on the straight due to toe in deflection .
UCR use chromemoly tube, tig welded brackets and jack point, and nut plates. powdercoated. Stiffens the car up, saves the pinch welds and most importantly makes it easy to jack the car up.
Old 11-26-2013 | 06:53 PM
colodude18's Avatar
Troof lol
In the few laps I was able to do with my new suspension (before my transmission failure) I took one corner a bit too fast and the car simply slid about one tire width to the outside of the turn (4-wheel drift) without any drama or skipping, then traction resumed as if nothing had happened. In the past that would have meant two-wheels-off. This suspension package makes the Cobalt corner like a go cart
Old 01-04-2014 | 12:19 PM
cranemaster's Avatar
Im having a clunking sound rear passenger side over small bumps.. its driving me nuts...
Old 05-07-2023 | 04:55 PM
Shane1771's Avatar
Install was relatively easy, although the damaged bushing took quite a few whacks with the hammer to get out. A heavy hammer will help, all we had was just a dinky claw hammer.
PRS Twisting Beam Bushings with hardware are 395.00 per set.
Ask John to send you the Kent Moore tool on loan. You NEED this to install them. (Come to think of it, I still have it, I promise I'll mail it back tomorrow Gloria!)
Damn son those are cutthroat prices. The best bushings you can get for those axles are Dormam premiums and they're $36 a piece with hardware.
Old 05-08-2023 | 09:51 AM
  #36
No Dorman bushings are not the best for the twisting beam. They're the "best" if you want stock and cheap, the PRS are not stock and are intended to help for road course racing.
Old 01-11-2024 | 03:43 PM
  #37
JapEatr's Avatar
South Central *********
These bushings are a muthafkr to get out of the rear beam
Monieg5gt (01-12-2024)
Old 01-12-2024 | 03:06 PM
  #38
Monieg5gt's Avatar
Yes they are. You need the kent moore tool.
Old 01-12-2024 | 03:14 PM
  #39
JapEatr's Avatar
i bought it and the bushings are still fighting me
Old 01-12-2024 | 05:25 PM
  #40
Monieg5gt's Avatar
You might have to burn them out. I know some people have had to do that. Do you planning on using stock bushings or those Powell one's? I actually have them but haven't put them in yet and i'm basically waiting for this last new set of oem bushings to wear out.
JapEatr (01-12-2024)
Old 01-12-2024 | 07:58 PM
  #41
JapEatr's Avatar
Nolathane Poly Bushings
Monieg5gt (01-13-2024)
Old 01-13-2024 | 08:30 AM
  #42
Monieg5gt's Avatar
Nice! And very good choice on going with the Bilstein shocks. I went with those along with lnf struts, and YYZ Springs. It gives a great ride for comfort and performance.
Old 01-15-2024 | 08:53 AM
  #43
JapEatr's Avatar
if i find a set of YYZ used, then im gonna snag em!
Monieg5gt (01-15-2024)
langaan
09-07-2017 11:30 PM
rckrz6
28
11-06-2012 08:40 PM
victoryredturbalt
03-13-2012 02:21 PM
Quick Reply: Rear suspension rattle? Check your bushings!
