Sagging or shock blow out?
Old 04-13-2012 | 07:17 PM
Play Pat's Avatar
Can't tell if I'm sagging or my shocks went out. I had 5 people in people and my car on eibach sportlines on stock suspension. On one side in the back is lowerif than one side and it's noticeable.
Old 04-13-2012 | 07:21 PM
zerosk8ter83's Avatar
if your shocks went out you would know,you would feel every bump on the dang street
Old 04-13-2012 | 07:25 PM
07blackg5's Avatar
Slobodan Milošević
one side of my car has been lower than the other since the beginning of time
its super noticeable because im on coils
Old 04-13-2012 | 07:32 PM
K-Train04RL's Avatar
These cars are weird one side is almost always lower. I think it's the pass. So dot worry do the bounce test to make sure ur good
Old 04-13-2012 | 07:45 PM
Play Pat's Avatar
Describe the bump test. I'm not understanding since I do
Have bump when I drive
Old 04-13-2012 | 08:04 PM
LS6Rally's Avatar
push down on the rear bumper, car shouldnt bounce more than 3 times.
But for you education: Regular Shocks (or Struts) NEVER effect ride height, only springs. Shocks dampen Spring Oscillations.
Air and Hyd. Shock will alter height, but im 99.9999999999% sure you arent running those.
Old 04-13-2012 | 08:35 PM
Play Pat's Avatar
Ill try that when I go back to my car. It wasn't like that before. Now it's 2 fingers on one
Side and 2 on the other. Rear
Old 04-13-2012 | 09:16 PM
Play Pat's Avatar
Okay I tried it multiple times. When I tried pushing it down it down. Then just moved a little. Couldn't count how many times it moved since it was so quick and small.
Old 04-13-2012 | 10:11 PM
LS6Rally's Avatar
Your shocks are fine. are both of your springs seated correctly in the Perches?
Old 04-13-2012 | 10:18 PM
Play Pat's Avatar
If Installed them myself I would tell you, my university is located in the capital of my state. So I have no where to work on my car. So I went to a place that specializes in lowering, they do a lot of performance work. Hopefully they did it right, but you never know. Could I tell from just looking?
Old 04-13-2012 | 10:20 PM
LS6Rally's Avatar
well the bottom of the spring should be sitting flat on the perch and the top coil should be level at the top as well
Old 04-13-2012 | 10:30 PM
Play Pat's Avatar
Ill try find somewhere to park and look. So I wont get ran over and have some light to look. thanks for the help, I'll tell you what I see. Hope its sitting right.
DANRICKARD
10-01-2015 01:08 AM
Tupp
09-30-2015 09:18 PM
soaxin
09-26-2015 09:41 PM
soaxin
09-26-2015 09:39 PM
09-26-2015 07:44 PM
