Stainless brake lines
Old 10-31-2011 | 09:00 PM
SaberD's Avatar
I tried to find some of the FTP lines, and I can't seem to find anyone that has them in stock. The FTP ones are teflon, and the goodridge ones are PTFE. wtf is PTFE and which one is better? what are some other options? i have the regular ss brakes, not the brembos.
Old 10-31-2011 | 09:32 PM
09sscalicobalt's Avatar
ottp sells them and so does john powell
Old 10-31-2011 | 09:44 PM
LS6Rally's Avatar
PTFE is Teflon.
Poly-Tetra-Fluoro-Ethylene
its just another name for it. we use it at work.
Old 10-31-2011 | 09:47 PM
SaberD's Avatar
Originally Posted by LS6Rally
PTFE is Teflon.
sweet dude thanks.
Old 10-31-2011 | 09:57 PM
SaberD's Avatar
It looks like ZZP has some, and they are in Michigan! I was pleased with the quality of the downpipe I bought from them, so I would expect decent quality from the brake lines as well.
- Stainless Brake Lines for your SS & Redline #
Old 10-31-2011 | 10:58 PM
Wangspeed's Avatar
ZZP ones only use one long line in back. Not correctly done. The rears should be 4 lines, and the fronts should be 2.
Old 10-31-2011 | 11:45 PM
SaberD's Avatar
thanks for the info. so are the goodridge ones ok?
Old 10-31-2011 | 11:46 PM
LS6Rally's Avatar
i believe Goodridge makes a 6 hose kit
Old 11-01-2011 | 10:01 AM
Wangspeed's Avatar
Technafit does as well, but I found out on my car that I have metric in front, and sae in back for threads. Thanks GM... Normally it should be M10x1.0, but in the rear of my car, I have 3/8"x24TPI. Go figure.
Old 11-01-2011 | 10:23 AM
SaberD's Avatar
do you have a link? I can't seem to find a 6 hose kit anywhere.
@wangspeed. why would it be only your car? what year/trim are you? I see that a lot of these brake line kits are specific to the year/trim. perhaps you received the wrong hose kit.
Powell Race Parts's Avatar
My TC ones suck ; dont sell them at the moment, I gotta get the manufacturer to change the spec., made wrong. Not a big seller and a PITA to correct. A November/December task.
Goodrich is good for LSJ/Redline
Old 11-01-2011 | 11:04 AM
Josh@ottp's Avatar
We have 5 kits of the 6 line kit in stock. FTP lines
Old 11-01-2011 | 12:01 PM
SaberD's Avatar
The website says it is out of stock. Are these the right ones? I only see 4 lines in the picture. How can I go about ordering?
http://www.ottperformance.com/store/...ine-51p180.htm
Old 11-01-2011 | 12:28 PM
Josh@ottp's Avatar
Try it now. Also that is a generic picture. I will get one taken and put up this week.
Old 11-01-2011 | 12:37 PM
Josh@ottp's Avatar
updated the picture just now.
Old 11-01-2011 | 12:41 PM
JimHarr18's Avatar
i've had the ottp ones in my lsj for probably around 6 months now. i like 'em. definatly mades the brake pedal feel harder. i'd recommend them. i got red ones, and if you look hard you can see them, but they don't stand out in a bad way or anything like that.
Old 11-01-2011 | 02:39 PM
SaberD's Avatar
I have placed my order. Thanks!
Old 11-01-2011 | 02:54 PM
evil ss's Avatar
Are the rear lines the same between the sc and the tc because I have brembo fronts I'm going to swap to over the winter and when I do I want to do steel braded lines
Old 11-01-2011 | 04:15 PM
Wangspeed's Avatar
09 SS Sedan. I don't have the wrong kit. The kit is right, my car is screwy. I'm not the only one with this problem. An SS sedan near me actually has M10 on one rear side, and 3/8x24 on the other. Maven has also documented this problem.
Old 11-01-2011 | 07:06 PM
toolman's Avatar
My 2007 G5 GT also has the same problem. I have the FTP lines on the front, but stock on the back. I put them on about 2 years ago, but I'll be replacing them with something else soon. The plastic strain relief parts near the fittings don't seem to hold up very well, and I'm worried about the lines failing.
Old 11-01-2011 | 11:30 PM
Wangspeed's Avatar
I'm ordering some custom 3/8 x 24 lines from a friend of mine that is a brake parts dealer. He sources his lines through Technafit. Should be able to do the same for you if you like.
Old 11-02-2011 | 06:04 AM
stormtrooperxl's Avatar
Is that kit compatible with all cobalts or just the lsj and lnf?
Old 11-02-2011 | 02:06 PM
Josh@ottp's Avatar
In case you didn't know FTP use's technafit products. I called technafit a long time ago and they sent me to FTP.
Old 11-02-2011 | 02:36 PM
Wangspeed's Avatar
I was just replying to toolman, who has the same screwy issue that I do. Metric in front, SAE in back.
Old 11-03-2011 | 01:30 PM
toolman's Avatar
I'm in no rush to change the rear lines. I've been considering just having the fittings on the hardlines changed to metric. It's just a flare fitting, right? That way I don't have to deal with it if I ever have to change brake lines again.
