Steering Rack Spacers?
The OTTP spacer I got did not have a depression in it. I have seen some pictures that do have a depression. Maybe it's for the thicker ones, or maybe it's just a TTR thing. Anyways, when you look at the rack, you'll see that the depression goes on the top, because the rack has a built in washer like area around the bolt.
I'm sure John can give you an answer on this one, about what the purpose of that spacer/washer like area is for. I can't. I just know it's there stock. The only thing I can think of is to allow for a little bit of separation to prevent corrosion. I dunno. Just a guess.
I later reviewed what I was doing, looked at the flat surface of the cradle, where the rack mounts, I looked at the compression of the isolator sleeve and concluded that I had been a little silly, ovethinking things. All rack spacers I make are now flat. TTR copied the stuff and didnt know why so until they read this they are still making the recess without knowing why. BTW costs more to do it that way.
correct. with the new LS mounts I will ship next week, you wont have to do that. They are rotated btw please dont tell ZZP.
Very easy, Although I havent had time t install mine I have had to change my steering rack before and if you have an issue installing these you probably shouldnt even be changing your own oil.
Well yeah i figured it out. Lol. That left side was a p.i.t.a. Such limited space. Right side literally took a minute to do.
But none the less Pedders/Tc combo FTW, no squeaks or rattles. Looks and ride very nice.
Qwik i got mine from OTTP with the recess in, believe it or not i think it actually helped line up the holes for the bolts since its such a tight fit for the bolt.
Correct you are sir.
Thanks for reply.. lol.. no need to be an ass.
wait??? u have to grind the trans mount to get them on an ls? WTF? im not doing that to my car. how much do u have to grind it?
damnit i just got my springs and rack spacers last week now im prob going to send them back
#36
OK.. so I finally got around to doing it.
No real problems except on the drivers side, when we went to drop the bolt back into the rack we had some problems lining it up. Took a bit of adjusting to get things all back in place.
Here is a pic of the long bolt you need to take out, lift up the rack and slide the piece underneath.
#37
I just installed these when I installed my progress springs. Alignment was off by a bit still. Toe was off. There is hardly any bump steer, however there is very little clearance on the driver side between the steering rack and rear transmission mount. Just purchased the ottp stage 1 mounts for more clearance. When I install the stage 1 mounts I will take pictures of the steering rack spacers. Install is just two very long bolts that are hard to get to.
#38
question someone please anwser!!! I lowered mine about 4 months ago on sportlines and i never installed these. I got it aligned day after i installed so am i fine without these like will it **** up my tires by not getting these?
#39
You would have to re-align after getting the spacers. Bump steer is annoying, but I guess if you don't know any better than you won't realize what a nuisance it is. Me? I hate it. I put the right spacers in for the Pedders drop. No bump steer. Go google for bump steer on a macpherson strut setup if you want to learn more.
#41
81 FT.LBS for rack bolts, check the how to section for spring install and torque values
https://www.cobaltss.net/forums/how-...ing-r-r-23418/
I used this one, well written, good pics and ....torque values
#45
#46
just want to double check
#47
LOL. No, the spacer goes underneath the steering rack, in between the rack and the cradle. If you stuck it on top, it would do nothing. Your goal is to move the rack up. Just like someone mentioned earlier in the thread, you have to pick up the rack and slide the spacer in between.
edit: loosen one bolt, but leave it partially threaded. Remove the other, and do that side first, then put the bolt back halfway back in, and move to the other side.
