Suspension and brake facts (FE1, FE3, FE5, J41, JM4, JL9)
Old 10-16-2011 | 03:00 AM
  #301
blu3_v1p3r's Avatar
This may have been answered in one of the last 300 posts, but I don't really want to read all 300 of them. Are FE5 LNF or LSJ lower control arms direct swap for FE1 lower control arms? If not what parts will have to be changed in order to make it work?
Old 10-16-2011 | 01:33 PM
  #302
Maven's Avatar
Yes, direct swap.
Old 10-16-2011 | 01:37 PM
  #303
royce777's Avatar
i have full fe3 suspension for sale. only 19k miles
Old 10-22-2011 | 09:35 PM
  #304
07cobaltLScoupe's Avatar
so i have a base LS currently on eibach pro- kit springs, moog endlinks, and OTTP rack spacers and i'm looking into possibly getting megan racing coilovers around christmas or next spring but i'm wondering what spring rate would be better for spirited daily driving right now... 10kg front / 8kg rear or 6kg front / 6kg rear
Old 01-04-2012 | 05:02 PM
  #305
FryLoch's Avatar
LNF Knuckles will bolt directly onto an 07 SS/SC right?
Or do I have to have the LNF hub as well, if I have the hub, that means I have to have the LNF axles as well correct?
Also, I saw a few posts about it but nothing real conclusive, I could do a complete LNF front and rear brake swap and not need to replace lines, MC, booster etc etc, just the front hubs?
Old 01-04-2012 | 07:22 PM
  #306
Maven's Avatar
You need the LNF hub too, and axles, and youll lose your ABS because the wheel speed sensors are different.
You dont need to change hubs to do a brake swap.
Old 01-06-2012 | 03:45 AM
  #307
FryLoch's Avatar
Is there any way to get around this. I'd like LNF axles, knuckles, hubs and brakes.
Old 02-05-2012 | 05:13 PM
  #308
noorj's Avatar
does anyone know what lug nut size our lugs are? i think 12x1.5 but im not sure
Old 02-17-2012 | 09:38 PM
  #309
08baltls's Avatar
How much lower do the ss/sc shocks and struts sit as opposed to the stock 08 LS shocks/struts? Cause I wanna go a bit lower then just the 2" drop I've got from my lowering springs without buying full coilovers.
If I used my 2" drop springs on ss/sc shocks/struts how much of a drop could I expect to see?
Old 03-06-2012 | 09:05 PM
  #310
metzO7's Avatar
Does anyone know the stock ride height for a 2006 ss sc? Cant seem to find the answer anywhere, I beleve I have a stock springs but want to make sure before I buy some lowering springs. right now im at 2-3 fingers between the top of the tire to the finderwell which seems low based on pics ive seen of other cars, im also on 225/4518 GY Eagle GTs if that matters. thanks
Old 03-24-2012 | 10:01 AM
  #311
@nt1ric3-420$$'s Avatar
so acc to factory specs the FE3/5 are different and im sure they are, but has any1 else noticed the aftermarket replacement dampers like monroe/gabriel blanket ALL models? LT LTZ SC NA even HHR? so are they that good or are you de-tuning ur suspension by installing these?
Old 10-05-2012 | 11:16 AM
  #312
09LAP's Avatar
^^^same but diffrent. i have the J41 the single iron piston 50mm. wondering how to get something better. i found new rotors but no one makes a single kit for mine other than the big brake kit and i dont need to spend 1K just wanted something better on there... if theres nothing available whats the exact specs so i could have one custom ordered from wilwood? sorry FNG at brakes i just know how to change them...
Old 10-05-2012 | 01:08 PM
  #313
emiller's Avatar
I'm sure they only make the most common one ie fe1. So its a downgrade for fe3 and fe5 people.
Old 10-06-2012 | 06:33 PM
  #314
CordiaDOHC's Avatar
Originally Posted by Cobalt.101
maybe you should read a little more
so that means its not worth it
Seems to me that's what I said. But in a way that explained why it wasn't worth it.
Old 10-07-2012 | 10:58 AM
  #315
BigBrother's Avatar
09LAP - what car do you have?
If it's an SS s/c, the dual piston Brembos and larger front rotors from the SS turbo bolt right on, rears stay as they are.
If it's an FE1 car - don't worry about massive brakes; get good aftermarket rotors and HAWK HPS pads and call it a day; cheap and a big upgrade. Brakes matter, so cover those basics; but there are more important areas to put the money in a 4-lug Delta.
Old 10-07-2012 | 12:36 PM
  #316
09LAP's Avatar
yes its the J41 brake system, i just wanted a better looking caliper without painting it cuz that really looks cheesy to me :/
Old 10-21-2012 | 04:45 PM
  #317
CobaltFan06's Avatar
I'm looking at upping to a 2010 cobalt LT. I noticed it has the 08 sport fascia, would a 10 LT have an fe1 or fe3 suspension? What about brakes? Sorry if this has been answered, didn't see it on the list. Also noticed the wheels are the same as the 08 sport, they are a 5 lug bolt pattern.
Old 01-23-2013 | 10:57 AM
  #318
larryb73's Avatar
How much do you want for the fe3 suspension? I assume it will fit on a 07 SS/NA
Old 01-28-2013 | 05:18 PM
  #319
Halfcent's Avatar
I'm old school
If you have an 07 SS/NA, then you already have an FE3 suspension. Also, you will have better luck getting a response if you PM the poster directly instead of within the thread.
Old 03-22-2013 | 10:25 AM
  #320
2009 Cobalt SS TC's Avatar
I have full Fe5 suspension for sale along with Speedy Lite 5 silver 18 x 7.5 four lug rims and a Dc Sport strut tower brace.I also have a brand new PPE Engineering. 2.2 L Lap header and catted downpipe with bung for wideband. I am also looking to get rid of the Cobalt SS Pioneer sound system. Anyone interested let me know.
Old 03-25-2013 | 06:07 PM
  #321
06SS ALL DAY's Avatar
anyone have the part number for the wheel bearing / hub assembly for a 06 lsj g85? i seen u guys talking about it on page 2 or whatever but nobody came through with it.
timken or ac delco is fine
Last edited by 06SS ALL DAY; 03-25-2013 at 06:07 PM. Reason: Automerged Doublepost
Old 03-26-2013 | 07:31 PM
  #322
Halfcent's Avatar
I'm old school
Nope, but I can tell you I bought mine of off Amazon. They were Raybestos, they work great, and they were ridiculously cheap.
Old 02-23-2014 | 06:56 PM
  #323
floria1985's Avatar
Are the rack and pinions for the FE1, FE3 and FE5 interchangable?
Old 02-23-2014 | 09:28 PM
  #324
andrewcarr1993's Avatar
Yep all the same. The quicker steering ratio on the 08-10 LNF's are from the change in the knuckle.
Old 02-25-2014 | 05:56 PM
  #325
floria1985's Avatar
good deal, the inner tierods on my FE1 are shot and they are non-servicable and i dont want to drop $300 on a rack and pinion if i can use one for a FE3 that costs $180. Any idea if the outer tierods are the same as well?
