Suspension and brake facts (FE1, FE3, FE5, J41, JM4, JL9)
Old 02-25-2014 | 10:16 PM
  #326
BLKLS's Avatar
I thought fe5 and fe1 racks where different?
Old 02-25-2014 | 10:40 PM
  #327
andrewcarr1993's Avatar
Nope, and Moog does sell inner tie rods so I would think they are serviceable.
Old 02-26-2014 | 08:29 PM
  #328
floria1985's Avatar
the FE1 inners are not repaceable which is why the rack is so expensive compaired to the others, according to chevy dealership
Old 02-26-2014 | 08:44 PM
  #329
Well I'm going to trust Powell and say they are all the same.
When someone asked the differences this was the reply.
none. they are all the same. its the knuckle steering arm is different. Buy the cheapest one from CED good luck with your ride
Old 02-26-2014 | 08:50 PM
  #330
Powell Race Parts's Avatar
troof. all racks the same
Old 03-01-2014 | 02:26 PM
  #331
floria1985's Avatar
idk why GM would sell an FE1 rack for $350 and tell you it isnt serviceible but sell you a FE3 or FE5 and tell you that it is serviceible, kinda rediculous if you ask me. i bought one for FE3/FE5 its going in today, any tips/tricks would be usefull
Old 04-24-2014 | 04:06 PM
  #332
Richie353's Avatar
In Reference to the well laid out part numbers list, where would the part number be found on the actual strut and spring assembly?
Old 04-24-2014 | 07:29 PM
  #333
Originally Posted by richie353
in reference to the well laid out part numbers list, where would the part number be found on the actual strut and spring assembly?
ced
Old 04-25-2014 | 02:37 AM
  #334
Richie353's Avatar
ced
Noob here, what is ced?
Old 04-25-2014 | 10:35 AM
  #335
Crate Engine Depot, a vendor here.
Old 09-12-2014 | 02:21 PM
  #336
tomiller's Avatar
ion fe1/fe2
Originally Posted by Halfcent
This is a sticky covering the various OEM suspension and brake packages available on the different models Cobalts. I do not have all the facts yet, and will note where information is needed. If you have a fact, post it, and I'll add it to the list.
Thanks to Maven for a lot of info. Instead of re-posting here, look below for a nice part number list.
The suspensions:
Starting with the FE1, and then the changes with each up-level system
FE1 suspension
19-mm front stabilizer bar
16-mm rear stabilizer bar
Stamped steel front lower control arms
FE3 suspension
22-mm front and rear stabilizer bars
Cast aluminum front lower control arms
FE3 shocks and springs
FE5 suspension - 2005-07 years
24-mm front stabilizer bar
FE5 shocks and struts. The springs may be different from some FE3 models.
Larger front end links
FE5 suspension - 2008 and up years
24-mm rear stabilizer bar
NEW FE5(LNF) shocks, struts, and springs.
Updated front knuckle
The Brakes
Brake systems are independent of suspension system, even though many parts are dependant on each other
J41
Front disc; 256mm x 23.69mm front rotors, 50mm single piston iron calipers
Rear drum; 50mm single piston iron calipers, 9.06" rear drums
4x100 wheels
(LS/LT)
JM4
Same as J41 but with ABS
(LS/LT w/ABS)
5 Lug JM4
ABS front disc; 276mm x 23.69mm rotors, 52mm single piston iron calipers
Rear drum; (unchanged except for 5 lugs)
5x110 wheels
(LT w/ABS and upgraded wheels, LT2, 2009 LT2 Sport)
JL9
ABS 4 wheel disc; 296mm x 26mm frt rotors, 54mm single piston iron calipers
Rear; solid 270mm x 14mm rear rotors, 38mm single piston iron calipers
5x110 wheels
(SS/SC, SS/NA, 2.4L Sport)
JL9/LNF
ABS 4 wheel disc; 315.5mm x 26mm frt rotors, 38mm 4 piston Brembo aluminum calipers
Rear; vented 292mm x 19.9mm rear rotors, 40mm single piston iron calipers
5x110 wheels
(SS/TC)
The Cars
These are just Cobalts. If anyone can fill me in on G5's, Ion's or HHR's, I'll add that.
2005
Base, LS, LT - FE1 with J41 or JM4
SS/SC - FE5 with JL9
2006 - 07
LS, LT, LTZ - FE1 with J41, JM4, or (2007) 5-lug JM4
SS/NA - FE3 with JL9
2008 (updated FE5 specs began this year)
LS, LT - FE1 with J41, JM4, or 5-lug JM4
Sport - FE3 with JL9
SS/TC - FE5 with JL9(LNF)
2009
Part interchangeability
So far, and to the best of our collective knowledge, every single suspension part is completely interchangable between models. Some rules apply, which are listed here:
1. If you change the front anti-sway bar, you must be careful to get the proper model year. As explained below by Maven, the FE5 front bar mounting changed between 2005-06. It appears the simple trick it to just get the 2005 FE5 parts to insure compatibility.
2. You can change the rear FE1 axle to an FE5 axle. The FE5 axle has provisions for mounting rear disk brakes. So you either have to cut those off to put on your drums back on, or you have to convert to rear disks. Converting to rear disks does NOT mean you have to convert to 5 lug hubs, but you are going to have to find some 4-lug rotors!
3. Knuckles are the same on every suspension up through 2007. In 2008, the FE5 knuckle was updated with various improvements for bump steer. It is NOT interchangeable. You can still use the GM Racing knuckles for those earlier years
4. Every other part should be completely compatible. For instance, you don't have to use FE1 struts if you want to put on FE5 springs, and so forth.
_________________________________________
I'm still collecting my data and making changes to this. I wanted to get it posted right away in case any help can be offered. Anything you can give, part numbers, spring rates, off the wall stuff, post it up.
does anyone know if the fe2 control arms for a 2003 ion can be replaced with fe1 or what the differnce is
Old 09-12-2014 | 08:21 PM
  #337
Subd
Old 09-12-2014 | 09:16 PM
  #338
Both are steel both have crummy soft cabs.
Old 09-12-2014 | 10:41 PM
  #339
JapEatr's Avatar
South Central *********
How have i never seen this thread before?
Old 09-14-2014 | 07:38 PM
  #340
They get lost with everything else lol that search button sometimes gives you what you want
Old 01-17-2015 | 07:27 AM
  #341
erockxp's Avatar
So does anyone know if the FE5 shocks and struts for 2008 - 2009 are shorter and if so by how much? I am guessing if I swap my FE3 for FE5 I should order springs meant for the turbo balts?
Old 01-17-2015 | 02:15 PM
  #342
Not shorter at all, exact same size, better valving.
Old 01-17-2015 | 05:21 PM
  #343
erockxp's Avatar
Oh okay thank you! Somebody else on the forum said they were shorter, glad I asked!
Old 01-19-2015 | 03:19 AM
  #344
Maybe you're thinking end links, that's the only thing shorter between FE1, FE3 and FE5. I know FE1 is longer than FE5 and forget if FE3 are the same as FE5 endlinks or FE1.
Old 01-19-2015 | 07:27 AM
  #345
erockxp's Avatar
Yeah maybe that is what they meant. Thank you suspension guru!
Old 01-28-2015 | 06:03 PM
  #346
BALCIAR's Avatar
susp. swap lt to ss(super sleeper)
i got a 2006 Lt and i turning it into a ss sleeper. i got a guy this thats gonna sell me a complete ss suspenstion with a.m. coil overs for a $100!!!! bad ass deal right!!!! i got an ss motor thats blown that im rebuilding. and i got a t3 t4 turbo kit with out the turbo manifold from a buddy for the low.
and 5-speed with the flywheel racing clutch and shifter and all that good stuff.
but my main question is about this suspentsion swap i got the ABS pump, the coil overs, control arms spindels front and back disc brakes with the back axel assembally, all four hubs, sway bar and links. so wil i be able to swap everthing over with out having an ss rack and pinion, and can i use my factory abs pump and master cylinder. also is their any thing else i wouild need to know or have to buy.
any input would be greatly appreciated
Old 03-05-2015 | 09:28 PM
  #347
Fsanti87's Avatar
I got an 06 with FE3 with blown front struts. Would the FE3 springs interfere with anything if I upgrade the struts to FE5?
I tried looking it up but everything I found was all a mess and all the FE codes just started making my brain hurt >.<
Old 03-05-2015 | 09:53 PM
  #348
Just look at the last sentence or the one that says 4 on post #336 that shpuld give you your answer ^^^
Old 03-06-2015 | 12:29 PM
  #349
Fsanti87's Avatar
One I looked at that twice too. Too many numbers it was messing with my head lol
Old 04-03-2015 | 02:14 PM
  #350
volsfan92's Avatar
Are fe3 and fe5 control arms interchangeable?
