Suspension and brake facts (FE1, FE3, FE5, J41, JM4, JL9)
Old 05-18-2009 | 04:37 PM
  #176
BigBrother's Avatar
My front end is "clunking" over bumps and with shrp left/right manouvers (both directions) i.e., lane change or slalom. Thught it was the endlinks; replaced them with powergrids - now I have adjustable endlinks AND a clunking front end, lol.
I'm thinking control arm bushings? Anyone think otherwise?
If that's it, I can't find part numbers for the stock replacement part (must use stock part, otherwise I'd go FE5 and OTTP sphericals). Help there?
Old 05-19-2009 | 10:37 AM
  #177
Halfcent's Avatar
I'm old school
There is a TSB for clunking in the steering. It's a problem with the intermediate shaft. If you are still under warranty, the dealer will fix it for free.
Old 05-19-2009 | 01:24 PM
  #178
BigBrother's Avatar
Warranty long gone. What's the fix? I thought there was a TSB for the LCA bushings as well? I looked, they're shot. So I guess I should fix both issues.
Need a part # for bushings.
Need to know what this intermediate shaft issue is and how to fix.
Old 05-20-2009 | 01:06 PM
  #179
Halfcent's Avatar
I'm old school
If you have inspected the LCA bushings and found them bad, just replace those. I noticed just now that you have a Saturn, so the steering item may not apply to you. Don't worry about the steering. If you insist, the TSB is published here on the site somewhere, try a search for it.
As for replacing the bushing, consider a couple of options at this time. You will have to purchase the bushings obviously, but then you will have to have a shop press them in for you. Does your Saturn have the FE5 LCA's? If not, this might be a good excuse for picking them up now.
Old 05-20-2009 | 02:22 PM
  #180
BigBrother's Avatar
Thanks for the reply.
Found he aprt numbers, not so much luck finding them in stock.
Don't need a shop to press them, there's a tool for that.
I've been looking into the FE5 LCA's for a long time; I want them. I also can't run them in SCCA Stock class, so even if I pick them up, I can't install them until next season.
Thanks!
Old 05-25-2009 | 03:42 AM
  #181
CobaltSSilver's Avatar
LNF/FE5 Part numbers
Sway bar: 15782696
Clamps: 10389617(same as 06-07 FE5)
Insulators: 25847760
Rear Axle: 25864579
Links: 20784688( ALL FE5 same)
Struts: 19181044/19181043(L/R)
Shocks: 25793745
Frt Springs: 25833647(L/R same)
Rr Springs: 25821162
Lower control arm: 25930725/15803767( L/R, right same on ALL FE5)
Knuckle: 25923942/25923941(L/R, unique to LNF)
Ya I don't think I will do all of these to an SS/SC but are all of these parts interchangable with my 2006 SS/SC?
Old 05-25-2009 | 09:36 PM
  #182
Halfcent's Avatar
I'm old school
The knuckle is not. The rest is. With your 2006, you wouldn't need clamps or links.
Old 05-25-2009 | 10:33 PM
  #183
tru2nrtt777's Avatar
FE5 part numbers
Clamps: 22608428('05 only , 1bolt/1slot) 10389617(2 bolt, ALL other FE5 including LNF)
So what would I need for my 06 LS to accept a FE5 swaybar 1 bolt clamps or 2? I would assume 2 bolt but you know what happens when you assume.
CED doesnt have the LNF swaybar
Old 05-26-2009 | 03:22 AM
  #184
Thanks....now the big question is do I continue to mod this car or trade up to the SS/TC or even the camaro....ugh.....
Old 05-26-2009 | 06:40 PM
  #185
Halfcent's Avatar
I'm old school
Easiest way to know is to go look at your car and see what you've got!
Old 05-27-2009 | 12:01 AM
  #186
Well currently my car is about 400 miles away.
Old 05-27-2009 | 12:35 AM
  #187
Maven's Avatar
if your car came with a 2.2 in it it has 1bolt clamps. and you need to just reuse them and order '05 SS bushings.
Old 05-27-2009 | 01:00 AM
  #188
Thanks maven.
Old 05-28-2009 | 05:10 PM
  #189
Sway bar: 15782696
Rear Axle: 25864579
Shocks: 25793745
So aside from shocks and struts what else would folks recommend if I want to update my SS/SC FE5? If I keep her I would do SSC lower springs instead of the LNF FE5 springs.
Old 05-28-2009 | 11:00 PM
  #190
That is all since you dont want the springs and you already have the endlinks, swaybar, control arms, ect.
Old 05-29-2009 | 08:01 AM
  #191
Ah so the knuckles and the struts/shocks are the only major changes then. Cool. Thanks guys.
Old 05-29-2009 | 05:30 PM
  #192
Well ofcourse the springs too but you already got that covered since you wanna go low.
Old 05-29-2009 | 11:34 PM
  #193
Ya I 'think' I want to go low. I may just do the updated FE5 springs, but we'll see.
With the Knuckles is it worth the trouble of trying to get them set to work on my SS/SC?
Old 05-30-2009 | 12:14 AM
  #194
Well that is a basis of opinion and since I grewup around fast hondas(490hp EF 4 door, 380hp ek hatch, 420hp em1, ect.) and they kept stock knuckles and sway bars I would assume you to be fine.
Old 05-30-2009 | 11:44 AM
  #195
Roger....thanks.
Old 05-30-2009 | 11:23 PM
  #196
Haha no problem. Hope I didnt come off as a dick.
Old 05-30-2009 | 11:39 PM
  #197
No you are fine. The big thing with the knuckles is if it will improve things...I am at such an impass. Keep the SS/SC upgrade the suspension among other things, trade it in on a SS/TC or go all out spend the extra money on a monthly payment and get a Camaro.....
Old 06-01-2009 | 07:52 PM
  #198
Halfcent's Avatar
I'm old school
You do not want to get TC knuckles. They are not compatible. That is discussed earlier in the thread. If you want upgraded knuckles, you will have to get the GM Racing set.
Old 06-01-2009 | 08:08 PM
  #199
Well if you get rid of it lemme get the Bwoody rear bar and the TTR rear Sway bar.
Old 06-01-2009 | 08:43 PM
  #200
I had seen they were not compatible or a direct bolt on but ya know somtimes folks retro fit things or fabricate.... I have an SV650S motorcycle and we are throwing on shocks and dog bones from Kawasaki motorcycles, so who knows man....thanks for the info though you are one of the few that pipes in these days.
Ya I will put stuff up for sale if I do get rid of her.
Last edited by CobaltSSilver; 06-01-2009 at 08:43 PM. Reason: Automerged Doublepost
